Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-04-2011, 12:34 PM   #1
shingles
How many bundles of shingle do I need for 3400 square feet?
Sharench is offline   Reply With Quote
Old 07-04-2011, 12:36 PM   #2
Framing Contractor
Rewards Points: 98
It depends on which shingles you use. Is 3400 sq ft the roof measurements or the house sq footage?
sixeightten is offline   Reply With Quote
Old 07-04-2011, 04:24 PM   #3
Architectural shingles generally are 3 bundles to 100 sq ft, 34 x 3 would put you in ballpark bout 102 , 3 tab shingles are the old flat style and they are generally 4 bundles per 100 square ,now do the math , and don't forget to figure in starter shingles and cap shingles depending on your style of ridge vent.
roofie is offline   Reply With Quote
Old 07-04-2011, 04:27 PM   #4
Framing Contractor
Rewards Points: 98
Most times 3 tabs are 3 bundles to a square. I have seen many newer architecturals that are 4 to a square.
The Following User Says Thank You to sixeightten For This Useful Post:
loneframer (07-04-2011)
Old 07-04-2011, 04:42 PM   #5
Sixeighteen is right bout shingles ,I had it backwards, but definitely beware of types of architect shingles the better a lot are usually the thicker thus making them less in each bundle. Rated by years like 30 40 50 years etc.
Old 07-04-2011, 04:57 PM   #6
kwikfishron's Avatar
Rewards Points: 92
There could be 3,4, or yes even 5 bundles per 100 sq. ft.
If you have a product in mind just look at the product info on the web or on the bundle itself for coverage.
kwikfishron is online now   Reply With Quote
Old 07-04-2011, 08:06 PM   #7
Thank you all for the replys, the roof measurement is 3400 sq feet.
Old 07-05-2011, 06:16 AM   #8
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
How many cap do you need? Now many starters? And figure about 8% or more in scrap. Hips and valleys can add 100' each.
tinner666 is offline   Reply With Quote
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 08:50 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 07:29 PM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 09:46 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 07:50 AM
IKO Shingles - beware mtugrad1985 Roofing/Siding 7 02-10-2009 04:42 PM
