Shingle Weaving Around Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-18-2012, 04:24 PM   #1
chimney was done last week before the roofing. They said the roofer would weave the new shingles into the lead surrounding the chimney. This to me does not look correct. Seems to me I will have water damage? Does this look correct to anyone?
Shingle Weaving Around Chimney-dsc02294.jpg   Shingle Weaving Around Chimney-dsc02292.jpg
fredicharles is offline   Reply With Quote
Old 07-18-2012, 05:46 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It wasn't a roofer that put those shingles up there. Are you sure the company had 'roofing' in it's name?
That's a disaster.
tinner666 is offline   Reply With Quote
Old 07-18-2012, 06:08 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Scary is about what I would describe it as.
The Following User Says Thank You to Windows on Wash For This Useful Post:
fredicharles (07-19-2012)
Old 07-18-2012, 10:02 PM   #4
Doing This Way Too Long
Rewards Points: 532
OMG, I'm sorry but that is just too funny!
Looks like something out of the shire.
Ummm, might want to get someone out there and do that properly
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Old 07-18-2012, 10:13 PM   #5
Rewards Points: 14,020
O/P said he's having new shingles installed, not that they have been installed.
Old 07-19-2012, 03:41 AM   #6
The chimney guy left the lead like that...roofers were here 3 days later.Should the lead be totally covered with the shingles?
These roof shingles are new. IKO Cambridge architectural.Roof was 40 square, about 100 sheets of 7/16 too. Judging from the comments should I have other concerns other than the chimney flashing?
Old 07-19-2012, 05:30 AM   #7
Pro Slate Roofer
tinner666's Avatar
I would be concerned about the nailing, pipe collars, starters, lack of ridge venting, and other issues after seeing that mess.
Old 07-19-2012, 07:02 AM   #8
+1
If that is what he left visible, what is invisible.
Old 07-19-2012, 04:15 PM   #9
RFN-4A-LVN
Roofmaster417's Avatar
If this is what they present as a topical installation I would be very curious to see whats hidden under,,such as nail pattern,felt installation,decking installation,decking fasteners,offset,length of fasteners used.And my list would go on for days if I was the recipient of that mess.
But all that lead you could use for fishing weights or even bullets,,,,Bullets ??? Hmmm..
Roofmaster417 is offline   Reply With Quote
Old 07-19-2012, 04:35 PM   #10
kwikfishron's Avatar
Rewards Points: 822
The Bricks look nice.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
seeyou (07-19-2012)
Old 07-19-2012, 05:34 PM   #11
Gymschu's Avatar
Rewards Points: 934
Even if that flashing is correct (and it's not) would you want that ugly looking mess on your roof? Yikes.
Old 07-20-2012, 08:15 AM   #12
Rewards Points: 850
what a mess. no roofer did that. seeing as its lead it could be done pretty much perfect, lead is soft and will from easy.
hotrod351 is offline   Reply With Quote
Old 07-20-2012, 09:57 AM   #13
I'm not a roofer or a brick mason.. but if that chimney was a new build, wouldn't it be the brick masons job to install the counter flashing in the mortar, and then the roofers job to install the step flashing behind that? Is that not the right way? In new construction would the roofer be up there cutting grooves to install the counter? No clue, here in phoenix fireplaces aren't that common, especially brick.
CopperClad is offline   Reply With Quote
The Following User Says Thank You to CopperClad For This Useful Post:
Tom Struble (07-21-2012)
Old 07-20-2012, 10:16 AM   #14
Rewards Points: 532
Copperclad, there is no CF required on that chimney. The lead is weaved into the shingles like step flashing and that is all that is required. It's old-school and lasts forever done properly. The masons did a very nice job from the looks. It just needs an experienced roofer to properly finish it and the HO will have a very sound detail he will not have to ever worry about.
The problem is the roofers dropped the ball. Odds are they had no clue what they were looking at and I'm going to bet there is step flashing hidden underneath that lead that should not have been installed.
The only thing keeping that from leaking right now is that it is at the ridge and the backpan lead drapes over it.
Old 07-21-2012, 10:32 AM   #15
Tom Struble's Avatar
Rewards Points: 2,002
many masons don't flash their own work on chimneys around here
usually see a roofer or a sider cutting in the counter
Tom Struble is offline   Reply With Quote
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
