Shingle Roof Leak And Hurricane Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-13-2013, 10:18 AM   #46
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I'm expecting you to find plywood. If it's wood, you're good to go.
Screws hold better. Airspace isn't necessary, but MBCI offers some extended cleats that provide 1/4" to 3/8" airspace. 24 ga. metal is preferred.
tinner666 is offline   Reply With Quote
Old 10-13-2013, 11:13 AM   #47
Rewards Points: 154
There is a reason why roofers minimize the amount of cement and caulk they use on installs. Excessive amounts of gunk on a roof traps water and forces it under shingles, creating more leaks. That is why people who attack roof leaks with big mounds of caulk, cement, and tar usually have new leaks develop right after their 'repair' work.
eharri3 is offline   Reply With Quote
Old 10-14-2013, 08:51 AM   #48
Roofmaster
Rewards Points: 2,210
Blatant, gross generalizations about which roof system will survive high wind events without even knowing what the substrate, or method of attachment, is kind of ridiculous. Wind resistance is only as good as the weakest link.
If I was to use a metal roof where you are, I would use a batten seam system, so I could remove and replace panels damaged by tree fall. Use a galvanized steel panel with a 70% Polyvinylidene fluoride, or polyvinylidene difluoride (PVDF) paint coating, (Kynar 500, it's like band aid) and use the number of clips recommended by the manufacturer for the anticipated wind speed. The clips should be screwed down with square drive minimum No. 12 fasteners at two per clip into a sound substrate. Follow Tinners advice for spacing, and run panels from eaves to ridge continuous.
Google MetFab A good friend of mine started that company and he knew his chit.
The Following User Says Thank You to jagans For This Useful Post:
paulmars (10-14-2013)
Old 10-14-2013, 03:28 PM   #49
Rewards Points: 117
met-fab.com ?
paulmars is offline   Reply With Quote
Old 10-14-2013, 07:59 PM   #50
Roofmaster
Originally Posted by paulmars View Post
Yes www.met-fab.com
You can check out their construction details even if you buy from a local provider near you. The key is 24 gage Kynar if steel, .040" if Aluminum. There are a lot of Metal Systems on the market, though.
Old 10-16-2013, 05:43 PM   #51
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Agreed....I will still take metal over asphalt any day if the substrate is solid.
I love that you are the post police though....
Old 10-17-2013, 08:32 AM   #52
Roofmaster
Comes from experience. You should see how some of the roofs that I have done forensic work on were fastened down. Clips fastened to 1/2 inch OSB 4 ft. on center with one roofing nail. 24 inch wide panel.
Metal is great as long as the designer and installer know that it moves a lot, and how to handle that movement. Only educated people know how to do that. Again a gross generalization, but I have not met many residential roofers that spend much time in the Library.
Ill turn in my badge.
Old 10-17-2013, 10:08 PM   #53
Hurricane Sandy and Roof Leaks dajonx Roofing/Siding 15 11-03-2012 09:45 AM
Need help to locate leak in cathedral ceiling roof Kadath Roofing/Siding 9 09-08-2011 03:30 PM
How to install a flash (for a vent pipe ) properly Gnfanatic Roofing/Siding 34 06-08-2011 10:21 PM
New Roof Vs Insurance Miranda Roofing/Siding 3 10-19-2008 12:51 PM
