Shingle Roof Leak And Hurricane Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-12-2013, 05:43 PM   #31
Rewards Points: 91
Originally Posted by Windows on Wash View Post
Pitch is too low for a standard application shingle. By the numbers, you are under a 4:12 and there is no shingle manufacturer that will warranty that against leaks.
so what type of roof should i get?
these shingles were 40 year shingles. I paid extra for that.
paulmars is offline   Reply With Quote
Old 10-12-2013, 05:44 PM   #32
Rewards Points: 91
3.84/12 my math.
Old 10-12-2013, 06:04 PM   #33
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
How old is that roof?
Old 10-12-2013, 06:05 PM   #34
Rewards Points: 898
If you want something that is going to be permanent, spend the money on metal.
No matter the manufacturer, asphalt is not going to do well or have an enforceable warranty on it at that pitch and with that amount of overhanging vegetation.
Old 10-12-2013, 07:04 PM   #35
Rewards Points: 91
installed 1994
Old 10-12-2013, 07:05 PM   #36
Rewards Points: 91
see my point #5
Old 10-12-2013, 09:33 PM   #37
Roofmaster
Rewards Points: 2,172
These shingles are toast. Time for new shingles. Tear all off, Inspect and repair deck where needed, Use good underlayment ASTM D226 Type 1 felt, and a good three tab 30 year minimum shingle and you will be fine. Install all ventilated soffits and a good ridge vent.
Old 10-12-2013, 10:04 PM   #38
Rewards Points: 898
With that pitch and vegetation, I would go with metal.
Metal is better against wind lift as compared to shingles too.
Old 10-12-2013, 10:04 PM   #39
Rewards Points: 91
my 40 year shingles lasted 19 years. I want my next full roof job to out live me. Im 52 yo. Soffits are vented. Im still considering closing the ridge vents. Unless I can find a much better ridge vent to install.
im still not sure that a good thick coating or three wont get me another 5 years.
Old 10-12-2013, 10:08 PM   #40
Rewards Points: 91
I need specifics. ive read that some metal roofs are junk. Wont out live me. Wont withstand a hurricane, prone to leaking after some years, etc.
I just measured the pitch on one of the roofs. Its 3.84/12.
Old 10-13-2013, 09:54 AM   #41
Rewards Points: 898
There is junk in every sect of building material out there, but, by in large, metal will outperform and outlast asphalt.
What look do you want?
Old 10-13-2013, 10:02 AM   #42
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
20 years is a long time for a 40 year roof to last. A standing seam roof with cleats on 8"center should survive a cat 4 hurricane. Go 6"oc to be safe.
BTW, that linb damaged area was never repaired. Somebody just slapped some kinda department store stuff on it. A repair would have lasted 20 years.
tinner666 is offline   Reply With Quote
Old 10-13-2013, 10:05 AM   #43
Pro Slate Roofer
tinner666's Avatar
Matter of fact, on second thought, I'd cover the plywood with 1x6's screwed into the rafters. The wood will give 80% more holding power than osb or plywood.
Old 10-13-2013, 11:06 AM   #44
Rewards Points: 91
i dont care.
Old 10-13-2013, 11:11 AM   #45
Rewards Points: 91
what plywood? If and when the roof cover is removed, Id planned to use 9d shank nails to hold the planks to the rafters. Screws would be stronger.
does there need to be air space between the metal and the planks?
p
Hurricane Sandy and Roof Leaks dajonx Roofing/Siding 15 11-03-2012 10:45 AM
Need help to locate leak in cathedral ceiling roof Kadath Roofing/Siding 9 09-08-2011 04:30 PM
How to install a flash (for a vent pipe ) properly Gnfanatic Roofing/Siding 34 06-08-2011 11:21 PM
New Roof Vs Insurance Miranda Roofing/Siding 3 10-19-2008 01:51 PM
