Shingle Roof Leak And Hurricane Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-12-2013, 04:21 PM   #16
Rewards Points: 91
other end rear roof. arrow points towards patch in last pic. X is where another leak is. This other leak was not fixed when vents replaced. both vents this rear roof replaced last year.
paulmars is offline   Reply With Quote
Old 10-12-2013, 04:22 PM   #17
Rewards Points: 91
shingles wearing out
Old 10-12-2013, 04:24 PM   #18
Rewards Points: 91
other side rear roof, two X where two leaks are. these leaks not fixed when vents replaced last year.
Old 10-12-2013, 04:26 PM   #19
Rewards Points: 91
other view rear roof. arrow points toward that big patch from branch (other pic). these vents the ones replaced last year.
Old 10-12-2013, 04:27 PM   #20
Rewards Points: 91
same roof
Old 10-12-2013, 04:28 PM   #21
Rewards Points: 91
more missing
Old 10-12-2013, 04:29 PM   #22
Rewards Points: 91
another section
Old 10-12-2013, 04:30 PM   #23
Rewards Points: 91
front roof. two x where leaks are. these vents not replaced.
Old 10-12-2013, 04:31 PM   #24
Rewards Points: 91
damage? No leak.
Old 10-12-2013, 04:32 PM   #25
Rewards Points: 91
wear?
Old 10-12-2013, 04:33 PM   #26
Rewards Points: 91
other view front roof leak
Old 10-12-2013, 04:34 PM   #27
Rewards Points: 91
other view rear roof leak
Old 10-12-2013, 04:36 PM   #28
Rewards Points: 91
previously mentioned branch patch
Old 10-12-2013, 05:39 PM   #29
Rewards Points: 12,878
Those shingles are shot and need to be replaced.
The granules have all washed off long ago and there bare areas showing.
No ones mentioned this before while there where working on the roof?
Old 10-12-2013, 05:39 PM   #30
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Where to start...?
Roof is smoked and needs to come off. Sorry to be the bearer of bad news but there is more than enough wrong with the roof and the actual shingles that it needs to go.
Granules are coming off in droves.
Appears that you have a mix of dimensionals and 3-tabs from one of the pictures but
Patch is dead wrong.
Pitch is too low for a standard application shingle. By the numbers, you are under a 4:12 and there is no shingle manufacturer that will warranty that against leaks.
Hurricane Sandy and Roof Leaks dajonx Roofing/Siding 15 11-03-2012 10:45 AM
Need help to locate leak in cathedral ceiling roof Kadath Roofing/Siding 9 09-08-2011 04:30 PM
How to install a flash (for a vent pipe ) properly Gnfanatic Roofing/Siding 34 06-08-2011 11:21 PM
New Roof Vs Insurance Miranda Roofing/Siding 3 10-19-2008 01:51 PM
