Shingle Reroof: Metal Valleys Yes Or No? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-20-2005, 03:52 PM   #1
Shingle reroof: metal valleys yes or no?
I'm going to reroof my house with new 30 or 50 year arch. shingles. I've got a couple of areas where the roof lines intersect, about maybe 25 lineal feet total. One of the contractors that came out to give me a quote indicated that it's better not to install a metal valley since the nailed areas of the valley are an eventual source of water intrusion. He recommended doing a "california cut" where he would put triple underlayment in the valley area and overlap the shingles? I'm not so convinced that would be a better method to keep water from getting under the shingles. Which method is better?
Hossman is offline   Reply With Quote
Old 08-22-2005, 07:15 PM   #2
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Most all my shingle roofs are closed cut (aka california cut) valleys. Why use metal on a shingle roof for anything other than cosmetics?
Place ice shield in the alley before installing the shingles.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 08-22-2005, 09:11 PM   #3
Thanks. The contractor mentioned that he felt it was purely cosmetic as well.
Do I need to have the ice shield installed here in So. Cal?
Old 08-23-2005, 08:44 PM   #4
Grumpy's Avatar
Rewards Points: 540
Ice shield protects against water backup as well. I would be talking out of turn to say it is required but I know it can't hurt.
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
asphalt shingle Vs. standing seam metal jlandry Roofing/Siding 2 12-26-2005 10:06 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
