Shingle Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2013, 04:24 PM   #1
shingle question
Hi,
When you get close to the ridge of the roof how far should you shingle up to it before you add your ridge cap shingles?
markharmon is offline   Reply With Quote
Old 05-14-2013, 04:58 PM   #2
Rewards Points: 13,732
All the way up to the cut out for the ridge vent.
Old 05-14-2013, 07:21 PM   #3
This is for a small play house so no ridge vent. How would I then shingle to the ridge?
Old 05-14-2013, 07:32 PM   #4
Rewards Points: 646
Run both sides to the top, cut one flush to it and have the other side overlap. Make sure you run them high enough to have the caps cover part of the exposure.
PatChap is offline   Reply With Quote
Old 05-14-2013, 07:33 PM   #5
Doing This Way Too Long
Rewards Points: 532
until no salvage shows below the ridgecap. Just keep cutting the salvage off flush to the ridge. Should only be one or two courses. Don't worry about nailing through the shingle where the ridgecap will cover it.
OldNBroken is offline   Reply With Quote
Old 05-14-2013, 08:37 PM   #6
Why not ridge vent, play house or not it's going to help the shingle last far longer and keep the inside far cooler for almost no money and little extra work.
Old 05-14-2013, 09:24 PM   #7
what do you mean by salvage?
Old 05-14-2013, 09:36 PM   #8
How does a shingle over ridge vent work?
Old 05-15-2013, 12:06 AM   #9
Rewards Points: 532
Salvage is the part of the shingle that does NOT show once the next run of shingles is placed above it.
I wouldn't overthink this trying to figure out venting unless you really want to.
Old 05-15-2013, 05:05 PM   #10
How much of the sheathing on each side of the ridge board do you leave open?
Old 05-15-2013, 05:15 PM   #11
747
registered
747's Avatar
Rewards Points: 534
I think its 2 inches down from ridge. Stopping 6 inches before gable. You need to do both sides of ridge. I would double check with someone like jagan here.
747 is offline   Reply With Quote
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
dormer/shingle question markfitz Roofing/Siding 14 10-23-2009 12:37 PM
Shingle Roof Replacement Questions - Overlay vs Tear-Off /OC vs Tamko tecboy Roofing/Siding 12 06-28-2009 06:09 AM
shingle vent II and hip roofs tie in dondiy Roofing/Siding 2 08-11-2008 12:40 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
