Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-23-2007, 02:21 AM   #1
Default Shingle Installation with F5S Standard Drip Edge
I have read the discussions about whether to over hang the shingle or line up even with drip edge. I have not found a clear cut right or wrong way. However, I have not seen any discussions for when the shingle does not cover the top end of the drip edge. The drip edge of discussion has a lip that extends the roof edge ~1/2”. The previous roof had a shingle overhang about ¼” past the drip edge’s edge. The new roof was lined up just short of the edge or at best even in some places. Please see pictures below. Question for you pros: Given the photographs below, is this an expectable installation? If not, why and what are the issues this method cause long term? If this must be repaired, what is an expectable procedure for the repair?
Extra Information:
Elk starter strips were used all the around.
You can see the shingle is cut short at the top of the peak. This is throughout the roof were the shingles are trimmed.
Longer view
Photo shows edge meets the ridge cap and the ridge cap does not cover drip edge. In that cut in the drip edge is direct exposure to wood. Is there an easy fix for the ridge cap or would the entire ridge run have to be remove?
Photo shows the drip edge with old shingles removed.
Thanks for you profession opinions and suggestions.
ShortEdged is offline   Reply With Quote
Old 12-23-2007, 12:41 PM   #2
Pro Slate Roofer
Either a 'starter strip' or a drip edge sticking out as far or farther than the shingles will catch water. Bad. The 'roofer'? will tell you the drip edge has ridges to keep water running straight on down. Don't believe it. Water and dust will accumalate there and get the deck wet at some point.
I, personally, like running the shingles 1-1 1/4" over the shingle mold which flies in the face of some wisdom. Or, 1/2" past any drip-edge.
In 30 years of repair and installation, I never saw a leak from either way, unless there were other issues like un-nailed edges, starters without sealer strpis, etc.
tinner666 is offline   Reply With Quote
Old 12-23-2007, 12:45 PM   #3
Looks like the roofers had a few drinks before they cut that edge. I've always seen the shingles overhang the drip edge by approx. 1/2".
jerryh3 is online now   Reply With Quote
Old 12-23-2007, 02:21 PM   #4
Thanks Frank,
That is exactly what I feel the contractor will say. What can say in response?
Also, how would this type of issue fixed? I want to avoid a hack that will make it worse. Would it be a major rework?
Thanks again
Old 12-23-2007, 04:21 PM   #5
Super Moderator
I always extend the shingles at least 1/4" farther out than the drip edge metal.
Here is what can happen if you don't. I just recently had this situation occur on a roof where we did have the proper amount of overhang and I will post pictures when I get back in my office on Wednesday if you are still interested.
The water from an upper roof downspout was flowing properly, but at the one gable edge, without wind even blowing, it allowed the water to run off of the edge of the side cut off edge of the shingles and due to the cohesion tendencies, run back on the underside of the shingles until it got trapped between the shingles and the metal drip edge.
Then it ran down the slope, until the bottom of the last piece of drip edge metal intersected with another lower section of roof, and entered through the decking at that location.
I could only imagine how severe of a leak it would have been had the metal edging been extended out farther than the shingles.
This roof I am speaking about has been on for over 1 1/2 years, and just 2-3 weeks ago, was the first time it leaked in the attic, but the HO father said he was up on the roof and was doing caulking, and he caulked the bottom edge of the drip edge metal and I think his caulking has created a back up and damming affect with the downward flow of water.
In your case, as far as what can you tell the roofing contractor:
If it is a manufacturer extended warranty, it must be installed per the specifications to meet the qualifications for the extended warranty.
If it is not a certified contractor from the manufacturer, then they still need to follow the manufacturers specifications Firstly and then if it does not address this, then the NRCA specifications secondly.
Go to their websites and print out the pages. The NRCA manual for steep slope roofing is available online when you register on their site.
Ed
Ed the Roofer is offline   Reply With Quote
Old 12-23-2007, 06:45 PM   #6
Thanks Ed,
http://www.thegreathardwarestore.com/F5S-10-White-Standard-DripEdge-p/513390.htm
I believe this link shows the drip edge used on my house.
Not sure I found the sections you were referring to or not. What I found was section 3.5.1 Starter Courses in the NRCA Roofing and Waterproofing manual – Fifth Edition.
Not sure I read the manual correctly, but is stated:
The lower edge or edges of the roofing material should be even with the outer edge of the perimeter metal flashing if extended drip edge flashing is used. (According to the drip edge link above, do I have the “extended drip edge flashing?”) The picture in the manual appears to show the starter and the shingle lined up together.
Section 3.5.1 goes to say if an “L” type metal flashing or no flashing is used, extend the starter course beyond the perimeter eave and rake edges ¼” to 3/4”…...
Does this mean the installers who installed my roof did it correctly where the (only where the) edges line up? (i.e. am I reading the manual correctly?)
The Owens Corning Instructions says:
Trim 6 ½” off rake end of first shingle. Extend 3/8” beyond rake and eves, and fasten.
In the Owens Corning manual, there is no mention what to do if a drip edge is used, but it makes common sense to me that the shingle should extend beyond the drip edge.
Yes, I would be interested in seeing those pictures.
For the areas that do not either line-up with or extend my drip edge, what is entailed to correct this issue? Do they replace the bottom layer, or do I have a big mess on my hands?
Old 12-24-2007, 01:01 AM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
by what it says,only the areas where the drip edge isn`t covered are all right,personally I feel capillary action will cause a problem there,we overhang 1/2" on all drip edges at rake eaves(sides),you can remove nails on the last cap,fit one under and renail it,on the rake eaves :all the rake shingle pieces would have to be removed,and have new ones cut in,with the addition of tabbed pieces where the full shingles were installed---It wouldn`t be good in NY the way it is pictured
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 12-24-2007, 10:23 AM   #8
Pro Slate Roofer
"Extend 3/8” beyond rake and eves, and fasten."
In this case, the dripedges are 'the eaves and rakes. Extend past the dripedges.
When flush, capillary actions will occur. Water even wicks up under the shingles themselves as much as an inch sometimes.
Old 12-24-2007, 10:29 AM   #9
by what it says,only the areas where the drip edge isn`t covered are all right----THAT REFERRED TO THE MANUAL HE WAS READING,i WOULD NEVER DO IT THAT WAY !!
Old 12-24-2007, 10:55 AM   #10
In way over my head.
Clutchcargo's Avatar
I'm trying to figure out why the roofer just didn't use the edge of the drip edge as a guide when he cut the shingles back.
It almost looks like maybe the crew shingled first, forgetting the drip edge, then someone realized the error and slid the drip edge in under the shingles.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
Old 12-24-2007, 11:51 AM   #11
It seems the cut in parts would be the easiest part, but what about the felt paper underneath? Would it be compromised?
What about the first rows that line up on the edge? How would they fix that with out ripping it all up? If they lift up the first row and slide another single row in there, won’t the nails either be compromised or in the way? Since it is the holidays, we agreed to address these issues with the contractor after the holidays and we are trying to get a list of issues that need to be resolved and what are acceptable fixes and not some hack that will make it worse. I went around looking a lot of houses and did not find one that was trimmed back like this.
The drip edge was not replaced for the re-roof. The 4 roofer companies that provided a bid all said they could not get a drip edge like the one I have. Some even said it was custom made. After the job was complete, I utilized Google to help me identify what I believe the drip edge is, hence the title of this post. The day I was home and able to watch the installers, I noticed they were not overhanging the drip edge on the starts and were it needed trimming they cut it back to far. I have no idea why they did this. When the Forman showed up, I told him my concern. I first asked him how far over the drip edge should the shingles be overhanging the drip edge. He said around 3/8” or so. I then told him we have an issue. At this point the job was a little over half done. He down played it and said they were installing it to “his companies” specifications. Anyway, we are now in this situation. This is a Lifetime “prorated” high impact roof and I believe as you do, that this is asking for issues that should not be a factor.
Old 12-24-2007, 01:31 PM   #12
Super Moderator
Although the commonly accepted practice is to install an overhang by at least 1/4" to 3/4", it would seem that the written instructions from the NRCA manual you referenced would allow a flush install on the eave edges.
I wouldn't. Period!
On your gable edges, you do have what they refer to as an extended drip edge, commonly refered to as an ODE, (Overhanging Drip Edge), or T-style drip edge.
This must be a geographical disparity, because the suppliers around me sell all sorts of varying edge metals for different applications.
I use a regular Gutter Apron for the eave edges and the ODE for the Gable edges and sometimes a Re=Roof Edge metal that looks like a J-Channel or C-Channel to cover up a beat up rough looking top profile of an old crown moulding.
It is not too difficult to remove the gable shingles and reinstall properly cut sections to overhang the gable edge metal in a uniform pattern.
Have that done.
For the eave edges, they at least have a leg to stand on, but I would address this also, since their could be cappilary action drawing the rain upward as Frank had suggested.
If you have Grace Ice and Water Shield on the bottom 3-6 feet of your roof, properly installed, then don't let that even give you any concern at all.
I will post the pictures by Wednesday evening.
Ed
Old 12-24-2007, 01:50 PM   #13
Thanks Ed,
Weather lock/shield is only installed in the valleys.
We have ODE on the whole house not just the gables. In places the shingles are short on the eaves by 1/16” to 1/8” also. I plan on having them address that as well. Can that be properly fixed without removing the roof? Would modifying/fixing this with out redoing it all void the warrantee?
Old 12-24-2007, 03:04 PM   #14
You Can Do As I Said,the Paper Is A Vapor Barrier,a Few More Holes Won`t Hurt It
Old 12-24-2007, 03:23 PM   #15
Super Moderator
They will have to pull the nails from at least the 2nd course of shingles and then remove and reset the 1st course of shingles by a minimal amount to either be flush with or extend past the gutter edge metal.
This will result in a slight amount of additional exposure of the first course of shingles, but that will be very minimal and should not be a concern.
Man, they caused so much extra work for themselves by not doing it correctly in the first place. What a shame that someone was trying to do the job as fast as possible instead of as correctly as possible.
On a personal note, I just checked out the discarded thread of yours on the other forum and you probably owe MdShunk an apology for your disparaging remarks towards him. He is probably one of the most knowledgeable posters on many forums I have ever seen, particularly in regards to electrical codes, but other fields as well, and was attempting to direct you towards the correct forum for your question. He contributes excessively via his post count total, due to his desire to be constructive and help others be safe and do their job performance correctly.
Ed
More On This Topic
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
Tin roofs have been around for centuries. The tin roof at Monticello, Jefferson's home, is still in good condition, despite being the one originally placed on the house when it was first built in the 1800s. Occasionally, it is necessary to pop one or... Read More »
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The last full panel course is cut and installed. Vented top row flashing is then cut and installed as wall flashing. In snow climates rich foam... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be caulking our seams. Now that I have my new trim board on I need to go back and put caulking in all of the seams as well as all my metal. This is really going to help prevent any... Read More »
Vented Drip Edge? jovo14 Roofing 30 11-13-2007 08:26 AM
Portico Drip Edge handy man88 Building & Construction 0 10-26-2007 02:54 AM
Drip edge mattflytx Roofing 3 09-10-2007 12:53 AM
Drip edge on a shed roof. Scott Roofing 2 10-04-2006 09:22 AM
fascia and drip edge glassman General Discussion 3 10-02-2006 08:39 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
