Shingle Color For New Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-15-2011, 10:49 AM   #1
Shingle Color for New Roof?
I am going to be replacing my roof and need some advice on the shingle color. I will be going with IKO Marathon AR 25 shingles. I have a brick house but the brick is painted white. It is an old house and has a very steep roof. I am deciding between the Harvard Slate color or Charcoal Gray. I think both will look good but any feedback is appreciated. Thanks.
collins79 is offline   Reply With Quote
Old 08-15-2011, 03:11 PM   #2
Gymschu's Avatar
Rewards Points: 932
It's tough to tell a complete stranger what color roof you should go with. It all depends on what colors you want to accent on your home. Obviously the gray shingle colors are neutral enough that they won't clash with the painted brick on your house. I agree that either color is acceptable. Maybe if you are thinking of changing the house color in the near future, you should consider other options.
Old 08-15-2011, 06:30 PM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
IKO?
Well I will not slander againast the company in fear of a law suit, I would recommend you do a little research into that brand choice.
White matches everything. Good luck.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 08-17-2011, 04:50 PM   #4
Ditto to Grumpys reply...I like the Slate though...old house..
Denzo is offline   Reply With Quote
Should I replace my roof? skittlebear Roofing/Siding 8 04-10-2010 06:01 PM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
Shingle Roof Replacement Questions - Overlay vs Tear-Off /OC vs Tamko tecboy Roofing/Siding 12 06-28-2009 06:09 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
