Sheet Rock Screw Size? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-15-2009, 11:07 AM   #1
sheet rock screw size?
I am installing 1" 4x8 Rmax board under 1/2" sheetrock on to the 2x6 rafters as part of my ceiling project on my attic conversion.
How would you fasten the 1" insulation board? I'm assuming you run the board perpenticular to the rafters
Once up, I want to put insulation tape on seams before putting up sheetrock.
Also, what screw size would you use to go through the insul board and sheet rock?
Any help would be greatly appreciated.
Vermont1 is offline   Reply With Quote
Old 04-07-2009, 08:58 PM   #2
Knows enough 2B dangerous
Back when i used to hang drywall we used to use a "rule of thumb" that screw length should be double the thickness of your board...so we used 1 1/2 or 1 3/8th screws when hanging 1/2" board.
With the extra insulation there I'd say you would want to use minimum 2 1/2 inch screws....and probably 3" would be better
photolew is offline   Reply With Quote
Mold Resistant Sheet Rock MikeyP Building & Construction 2 02-01-2009 12:30 PM
Sheet Rock UpComingBuilder General DIY Discussions 7 12-19-2008 12:22 AM
Floor Joist and Sheet Rock houstonbrama Building & Construction 5 11-23-2008 01:34 PM
Painting over messed up sheet rock. emilyiam Painting 2 03-24-2008 04:00 PM
What size sheet rock for garage ceiling? Billy Boy General DIY Discussions 12 01-24-2008 12:36 PM
