Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-10-2011, 12:00 PM   #1
Sheet metal under a rubber roof? what is going on here?
Hi, I live in a Philadelphia rowhome. I installed cheap roof vents and in the process of cutting out the little square for the vents realized my rowhome has a metal roof covered by a rubber roof.
The attic area has a lot of mold, dry rotted wood, etc.
Is there supposed to be a layer of sheet metal over the planked wood? Then rubber on top of all of that?
To be clear... the layers are:
rubber
rubber
sheet metal (now I can see this between the cracks of the planked wood)
plank wood (visible in the crawl space/ attic)
The home was constructed around 1910 to 1920.
I am not doing any roofing myself. After looking at this, I think the entire thing needs to get ripped up to let the roof/ attic breathe. Without researching it, I'm assuming the metal traps all vapor and should not be there.
I'd appreciate any feedback.
Party on,
Philly metal causing mold
philasheetmetal is offline   Reply With Quote
Old 07-11-2011, 11:32 AM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
What type of "rubber" is installed? EPDM (real rubber) or modified bitumen (the rubber that isn't real rubber but people still call it rubber)?
Most likely this is what happened... Previous building owners went cheap and when the metal roof began to leak rather than tear it off, they just installed numerous roofs atop the old metal.
Without seeing the roof I can't really make a suggestion. You can learn more about flat roofing options and frequently asked flat roofing questions on my website. If you post some pics I'd be happy to make some recomendations.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-12-2011, 09:12 AM   #3
The metal wouldn't be trapping any more moisture than the 'rubber' roof. From the limited info I'd say your problems are more ventilation related.
A picture of the roof, and of the attic space would be nice (as well as any ventilation you have in the attic space.
shazapple is offline   Reply With Quote
Tags
metal roof, metal under rubber roof, rubber roof
not venting a metal roof penny0322 Roofing 6 03-25-2011 06:39 PM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 08:44 PM
Rubber Roof Sealant ninghai Roofing 17 03-08-2010 09:58 PM
Patio Flat Rubber Roof installed, and gutter cleaning - ripped off? mark2741 Roofing 17 03-08-2010 12:55 PM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing 2 09-12-2008 09:51 PM
