Shed Type Roof Addition On Brick Home? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-06-2007, 11:39 AM   #1
Rewards Points: 152
Shed type roof addition on Brick home?
I will be putting a wood frame addition onto my brick home. The roof will be a "shed type" roof.
Are there any websites that show the best way to do this?
sandyman720 is offline   Reply With Quote
Old 03-07-2007, 09:22 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
What part specificly? The roof flashing detail or building the whole thing?
Brik is offline   Reply With Quote
Old 03-07-2007, 09:36 AM   #3
Rewards Points: 152
I am looking for how to do the entire thing. The roof flashing is something that i am really wondering about, but everything i am interested in.
do you know of anyplace to get this?
Old 03-07-2007, 10:15 AM   #4
Handyguy
Brik's Avatar
No. You addition will have every element of building an entire house. Foundation, walls, windows, siding, drywall, insulation flooring, electrical, maybe even plumbing, gutters, etc.
These books might be useful
http://www.jlconline.com/cgi-bin/jlc...N/userpages/37
Get both volumes.
Old 04-24-2007, 01:02 PM   #5
1:12 pitch roof
Dear Brik,
"My addition is 15 x 25 and has a 1:12 pitch. I currently have rolled
roofing and have coated it once. It is about 13 years old and does not
leak. I am considering covering it completely with snow and ice shield.
Is it acceptable to apply the shield over the roof in its current
condition? What can I put over the shield to protect it? I am considering
Tamko heritage 50 year shingles, which has a strip of seal to help
prevent wind blow-off. When I first bought the place, it had shingles, which
did not blow off. "
any help appreciated.
Basic_Homeowner is offline   Reply With Quote
Old 04-24-2007, 02:13 PM   #6
Handyguy
Brik's Avatar
1:12 pitch is very low slope. Do not shingle it. Do not do roll roofing, like they sell at homecheapo either.
Your 'roll roofing' is likely something like a torch down modified bitumen roof. These are good for low slopes but are most often professionally applied. There are also cold applied similar systems. Essentially you would have something similar to the ice and water shield with a top layer bonded to it. The top layer can have granules imbeded in it or not. if not, it gets coated.
Another option would be a EDPM rubber roof.
Again, do not do shingles or the roll roofing sold at the home center.
As for the old roof. I am of the opinion you always get a better job when your remove the old roof. Additionally you can inspect the deck for problems and make repairs if necessary.
If you got the book I recommended your options are described on P262-269 of volume 1.
As for blow off of shingles. No, they wont blow off of a low slope roof. They will leak with heavy rain or wind driven rain despite the "strip of seal". That strip is on all shingles to adhere the shingles together.
Good luck.
Old 04-24-2007, 02:35 PM   #7
Thank you Bric!!
will the snow and ice shield (under the shingles) prevent the "leak with heavy rain or wind driven rain despite the "strip of seal". That strip is on all shingles to adhere the shingles together."
I am considering covering the old rolled roof completely with snow and ice shield.
condition?
thank you!!
Venting of Cathedral Ceiling on Shed type roof sandyman720 Roofing/Siding 7 08-02-2007 10:27 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
