Shed Roof---What Material? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-07-2009, 09:41 PM   #1
Shed roof---What material?
Howdy,
Planning a 12'x16' shed/hobby building with a slanted simple shed roof. Drops 2' over 12'. 6" overhang on all sides for a roof deck dimension of 13'x17'. Plywood roof deck--5/8" or whatever the standard thickness close to that is. Likely will be 2x8 rafters on 16" centers.
In Oklahoma. Sometimes we get a lot of rain. On rare occasions we get 6-8" snow. Sometimes ice. Located in fairly shady part of back yard.
Getting lots of opinions of what kind of roof. Wanted metal but I think the slope is too low. 90# rolled roofing with granules seems easy but I'm told that won't last long. Not too familiar with peel and stick or torch down.
More than willing to hire this out--just wondering what would be the best approach. There will be electronic gear in this shed so I don't want water also.
Eric
66merc is offline   Reply With Quote
Old 04-07-2009, 11:57 PM   #2
Just curious, but why would you not just go with asphault shingles? They are not expensive and are easy to install.
draynes is offline   Reply With Quote
Old 04-08-2009, 12:53 AM   #3
Its a 2/12 pitch.Its considered a flat roof.
johnk is offline   Reply With Quote
Old 04-08-2009, 06:41 AM   #4
This pic from another post looks nice. Would this cost a relative fortune to get a contractor out to do just 200sf? Would it be the best way or is it overkill?
Eric
Old 04-08-2009, 10:44 AM   #5
Only way to know is to get a local estimate
I'd buy ice & water shield down & then 3 tab shingles
Old 04-08-2009, 03:33 PM   #6
Thanks Dave.
Does the ice and water shield nail down? Is there a problem nailing the shingles through it?
Curious as to what you did with your shed extension. Looks like a little more pitch than what I'm planning.
Eric
Old 04-08-2009, 03:43 PM   #7
Ice & water shield has a VERY sticky backing
It basically seals the roof when applied correctly
On my shed - low slope - I used tar paper & 3 tab asphalt shingles
No leaks in 4 years
But its a pool cabana
I have an old stereo out there
But not any high end electronics
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
