Shed Roof Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-30-2013, 06:39 PM   #1
Rewards Points: 16
Question
I'm building a small (6x8) storage shed for garden tools in my yard in north Idaho. It will be wood frame construction with a comp shingle roof and vinyl siding. There will be no insulation or interior finishes. The attic will be open rafters with no ceiling. I would like your recommendations about venting: gable vents or soffit and ridge or high and low on one wall. Thanks in advance.
IdahoBob is offline   Reply With Quote
Old 05-30-2013, 09:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
Ridge and Soffit combo will probably move more air and keep it a bit closer to ambient.
Old 05-31-2013, 12:52 PM   #3
Low Slope Roofing
Rewards Points: 114
Cut holes in soffits about the size of wall grates, then install regular 505 or if you want to get fancy like I did buy the cheap clear plastic ones so you get more light in the shed, I used 3 on a 8x16 and 4 soffit vents.
Mostly i just didn't want it to get too hot or smell like gas, the not smelling like gas was more important.
1985gt is offline   Reply With Quote
Shed roof pitch question Kevin P. Building & Construction 12 05-17-2013 08:12 PM
8x12 Gable Shed - Roof Help wguttrid Roofing/Siding 9 05-17-2013 07:02 AM
Shed roof framing - rafter size recommendations? tpagel Carpentry 10 04-15-2013 07:20 AM
No starter strip used on shed roof install? waterskier_erie Roofing/Siding 4 10-31-2011 08:25 PM
Shed roof construction questions wombosi Building & Construction 3 10-28-2011 10:01 PM
