Shed Roof Ridge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-01-2007, 06:27 PM   #1
Shed Roof Ridge
Greetings..... getting ready to lay the roofing shingles for my new shed. Not sure what to do when I get to the ridge? This is a gable style roof. Plan on using asphalt shingles (basic). Shed size is 7 x 8'. Also, there is a break halfway down the slope with a about a 3 inch overhang.... it occurred to me that it might be a little tricky nailing down that shingle as it tucks up underneath... maybe there's a little trick to that? Any help would be appreciated.
renomger is offline   Reply With Quote
Old 10-01-2007, 07:10 PM   #2
If the shingle lay flat enough to conform to the pitch break, you can just continue shingling.
You may want to snap extra horizontal lines and adjust the exposure a slight amount, so you ensure the entire row hits that junction correctly and cosmetically.
Also, you can instal an angle flashing of sheet metal. Most roofing supply houses carry them and I would recommend you use an aluminum metal with a similar color to the shingles being installed.
Ed
Ed the Roofer is offline   Reply With Quote
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
Losing aggregate from asphalt shingle ridge bkspero Roofing/Siding 8 07-19-2007 10:40 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
