Shed Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-20-2014, 04:32 PM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Shed roof
I'm having a tough time figuring how many bundles I need to cover my shed , it is 324sqft, the 3 tab shingles I was looking at says coverage is 33 sqft per bundle. Does that mean I will need 10 bundles. I found this other site, which mentions how to figure out how many squares on the roof which is confusing me. Any help would be appreciated
Barry
Barry J is offline   Reply With Quote
Old 04-20-2014, 04:38 PM   #2
Rewards Points: 13,694
A square is 10' X 10', 3 bundles.
10 bundles may or may not do it because of waste, starter strips and caps.
I pick up 11 so you can finish the job, take one back of not needed.
Old 04-20-2014, 05:35 PM   #3
CRCA Roofing Contractor
RoofingTrades's Avatar
A general rule of thumb is add 10% for waste. With traditional 3-Tab shingles waste may be a bit more than with newer designer style shingles, specifically if you want to follow the pattern. A "square" in roofing terminology is 100 square feet. Joecaption is correct, add additional material as you can always return what you haven't opened. It'd be a waste of time if you're 99% done and short of just a couple of shingles and have to return to your supplier.
RoofingTrades is offline   Reply With Quote
The Following User Says Thank You to RoofingTrades For This Useful Post:
Roofers Advice (04-26-2014)
Old 04-27-2014, 12:08 PM   #4
Roofers Advice
Roofers Advice's Avatar
Hi Barry,
When you say it has 324sqft are you talking about the square ft. of the garage or roof. I ask because a commom mistake is to use the footage of the shed floor vs. the square footage of the actual rooftop.
Roofers Advice is offline   Reply With Quote
Old 04-27-2014, 12:39 PM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Measured the roof, not shed,
Old 04-27-2014, 12:45 PM   #6
Roofers Advice
Excellent.
You've gotten some great advice from
"Roofing Trades"+"Joe Caption".
So, have fun and let us know how it goes!
Adding a lean to roof to shed Mills314 Building & Construction 5 10-14-2013 09:57 AM
Ceiling joists with shed style roof? agent008 Building & Construction 3 09-29-2013 01:30 PM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 08:31 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
Shed Porch roof tying in... my5sons Roofing/Siding 7 10-27-2009 08:19 PM
