#1 |
Sheathing nails loose
I'm getting ready to roof the front of the house and have run across what I think is strange. A lot of the 8d common bright nails holding down the sheathing are loose. They either stick up an 1/8" or the flexing of the sheathing works them up. I pound them down, but they seem to keep popping up.
I've gone over many of the sheets and added 8d ring shank galvanized nails to suck it back up. Anyone run across this before? Is it common? UPDATE: I forgot to mention the house is about 25 years old. Last edited by FatAugie; 09-03-2007 at 08:00 AM. Reason: added house age |
#2 |
very common, a lot of this "working loose" happens when you remove the old shingles. Re- nail as you have been doing. Nail gun, if available will help with the "popping back out thing".
Be sure your sheathing nail patterns are up to newer local codes. |
#3 |
Super Moderator
I also find this common to inadequately ventilated attics. The excessive moisture gets absorbed by the deck sheathing and it swells or expands and then when it dries out over time is contracts.
It doesn't take much expansion and contraction to slightly yet continuously move the decking and it will continually work the nails loose, plus leave a larger diameter hole in the rafter from the "toggling" effect. This is why they seem to have no holding power when you sink them into the same nail holes. Ed |
#4 |
hopefully you`re removing the old ones,or renailing them at an angle so they don`t work their way back up thru your new shingles
#5 |
You can't just push them back in the same hole. These nails probably just missed the joist or caught the edge. Pull them out and renail above or below and into the joist.
Ron |
#6 |
that`s what I said ron
,reread it if you nail them at an angle, it`s not the same hole
#7 |
remodeling pro
[quote=FatAugie;61054]. A lot of the 8d common bright nails holding down the sheathing are loose. They either stick up an 1/8" or the flexing of the sheathing works them up. I pound them down, but they seem to keep popping up.
quote] Don't knock them back down, as you have seen they will just come back out again. Pull them and renail next to it with galvanized ring shank. Sounds like a good time to renail all sheathing anyway, and tighten the spacing up for modern practices as suggested. |
#8 | |
Sheathing nails looseQuote:
I see troubleseeker has also chimed in, with the same recommendation. It feels like a movement is afoot. Ron |
#9 |
okay,my bad
| Display Modes | |
| Rusty nails | FatAugie | Roofing/Siding | 6 | 08-28-2007 10:25 AM |
| Roof sheathing overhang on fascia | Clutchcargo | Roofing/Siding | 7 | 08-23-2007 02:02 AM |
| sheathing nails | farrington135 | Building & Construction | 3 | 06-11-2007 11:17 AM |
| Which nails are right for the job? | MIKEGOUGH1 | Building & Construction | 2 | 12-16-2006 11:54 AM |
| Deck nails | jimgibson | Carpentry | 12 | 10-09-2005 03:22 PM |
