Sheathing After Wood Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2013, 01:18 AM   #1
Sheathing after wood shingles
I have a comp roof over wood shingles. I'm assuming there are 1x4s across the rafters under the wood shingles. When I tear all the old shingles off, should I but the new sheathing on top of the 1x4s or tear them off as well and put the sheathing directly on the rafters? It seems like it would be easier and sturdier to go on top of the slats. Does the IBC address this?
ronle is offline   Reply With Quote
Old 04-28-2013, 01:44 AM   #2
Doing This Way Too Long
Rewards Points: 532
Over the existing skip sheeting.
OldNBroken is offline   Reply With Quote
Old 04-28-2013, 02:22 AM   #3
you're saying put another comp on and not tear off anything? I think my insurance guy said I couldn't do that.
Old 04-28-2013, 03:12 AM   #4
Rewards Points: 324
Tear off both layers of shingles, put the plywood over the 1x4s.
mgp roofing is offline   Reply With Quote
The Following User Says Thank You to mgp roofing For This Useful Post:
jagans (04-28-2013)
Old 04-28-2013, 11:09 AM   #5
Rewards Points: 532
That ^^^^
Old 04-28-2013, 11:14 AM   #6
Roofmaster
Rewards Points: 2,172
Follow MGP. If you have spaced sheathing, chances are you have a turn of the century home. If you do, chances are the rafters are not particularly on center. The 1 x 4's will allow you to use 1/2 inch (OK 15/32) Plywood. Use Fir, 4 ply minimum and space it 1/8 inch at all edges. You will be good to go.
Oh and everything has to come off after two roofs by code. You must have Horsefeathers up there to allow an asphalt roof over shakes.
Old 04-28-2013, 11:34 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,172
I hate to think how that looked.
Follow the above advice....you will end with a much better looking roof....
ddawg16 is online now   Reply With Quote
Old 04-29-2013, 02:44 PM   #8
Registered User
Rewards Points: 5,248
IBC requires 2-1/2" minimum length nails (footnote "I"), approved staple lengths per sheathing thickness listed, into framing members- through skip-sheathing boards or not; http://publicecodes.cyberregs.com/ic...?bu2=undefined End or edge joints must break on framing for full fastener penetration.
Gary
Gary in WA is online now   Reply With Quote
Old 04-29-2013, 06:06 PM   #9
Ok
So, if the plywood has to break on framing, the 1x4s don't make it that much easier, just more stable as I'm working on it, and less work to take off. And it sounds like I have to get 4" nails - 2.5" into the framing, 3/4 for the 1x4, and 1/2 for the plywood?
The 1/8" gap around the plywood is new to me (haven't decked a roof in 35 years). With those 1/4s, I wouldn't have to put the little clips between sheets, or are those what ensure the 1/8" gap?
Old 04-29-2013, 09:37 PM   #10
Rewards Points: 532
How many roofers actually make sure all the joints are hitting framing when they resheet over skip sheeting?
No you don't need the clips and we have always just made sure while we are fastening we hit the framing and at least one fastener per skip sheeting on the ends.
Old 04-30-2013, 12:43 AM   #11
Yeah, I thought the 1x4s more than compensated for a joint not meeting over the frame. I would thinking going over the 1x4s to make sure they're all nailed down properly would provide the connectivity to the frame needed. Then, maybe use screws instead of nails to fasten the plywood down to the 1x4s? Or at least around the perimeter of each sheet to not worry about hitting rafters?
But, I guess that's not what the code says.
Old 04-30-2013, 12:47 AM   #12
Hey Jagans, I haven't actually looked in the attic and just assume there are 1x4s spaced under the wood shingles, but come to think of it, all those houses I roofed years ago like that were turn-of-the-century. This home was built in the early 60s; what did they nail wood shingles to in those days? A saw a YouTube of guys tearing off wood shingles by rolling them up in the felt underneath, but all those old house I roofed didn't have felt under the wood shingles. Do you think this one would?
r
Old 04-30-2013, 03:10 AM   #13
Rewards Points: 532
r
60's odds are it's solid ship-lap decking.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 07:29 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
