Sensisble To Request Ice & Water Shield On Whole Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-03-2012, 11:10 PM   #1
Rewards Points: 366
Sensisble to request ice & water shield on whole roof?
Does it make sense to request ice & water shield throughout whole roof for underlayment instead of 2 layers of felt paper, for asphalt shingle roof.
Part of the roof is low pitch 2:12 (with rest at 4:12), and roofer bids either don't specify using the ice & water shield or only at parts of the roof. I assume whole roof means more $, don't know how much more. Just wondering if it was ever abnormal to request it for the whole roof.
My local is northern California, if that matters.
daluu is offline   Reply With Quote
Old 12-03-2012, 11:18 PM   #2
Rewards Points: 13,256
A 2-12 pitch is the absolute minimum for most shingles.
You would be far better off to concider another form of roofing on that low a slope.
EPDM, metal, there's also several other types that would work out far better.
Old 12-03-2012, 11:47 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
I think that I & W on the whole roof would be a waste of your money. In your location, I would question the need for I$W anywhere on the roof as you do not get any snow to worry about ice damming.
Joe is correct about the low slope roof.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Windows on Wash (12-04-2012)
Old 12-04-2012, 01:38 AM   #4
Rewards Points: 366
thanks I'll bear your comments in mind.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Ice and water shield SamReynolds Roofing/Siding 13 08-31-2010 03:03 PM
