Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-18-2011, 04:09 PM   #1
Semi flat roofing methods
What is the best method to use when roofing a semi flat roof
James Jagemann is offline   Reply With Quote
Old 02-18-2011, 04:28 PM   #2
Low Slope Roofing
Depends on how flat it is or isnt. If its under 2:12" you could use just about any flat roof product out there. Above that I would stick to shingles with Ice and water shield.
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
seeyou (02-19-2011)
Old 02-23-2011, 10:08 PM   #3
Use commercial grade pvc single ply roofing membrane.Good to go.
flatroofing is offline   Reply With Quote
Old 02-24-2011, 01:26 PM   #4
Shut in w/o Home
seeyou's Avatar
[quote=James Jagemann;593446]What is the best method to use when roofing a semi flat roof[/quote]
Is that on a Mack or a Peterbilt?
I'm guessing you mean a low slope roof. A little more info would help - there are lots of options, some of which serve some situations better than others.
Size, type (residential porch or warehouse roof), your climate, age of structure, over heated or unheated space, etc?
seeyou is offline   Reply With Quote
Old 02-24-2011, 01:56 PM   #5
Low Slope Roofing
I dont think he will be back.
duro last flat roofing cherylfromcanada Roofing 4 08-06-2012 12:19 PM
What is the best flat roofing system today? Assuming a gut rehab. BestNJRealtor Roofing 12 02-05-2011 10:23 AM
Ashphalt roofing - semi attached house gordon_roofer Roofing 0 09-16-2010 11:50 PM
Flat Roof Repair--Question on roofing type buncoroad Roofing 2 10-18-2009 08:35 PM
Flat Roofing michaelj5 Roofing 1 08-26-2007 12:21 PM
