Secure SR Clips To Shingle Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-18-2012, 02:01 PM   #1
Rewards Points: 77
Secure SR clips to shingle roof
Hello All,
I'm going to be installing some SR cable on my roof sometime between now and the fall to aid against ice damns. The cables I got come with good these metal clips seen here: http://www.radiantsource.com/cart/ca...t_detail&p=278 .What should I use to secure the clips to the roof? An adhesive of some sort, Id take recommendations or should I use tacks/nails? Whatever I get get at Home Depot or Lowes would be nice or if I need to order something online, I definately can as I've got time.
Thank You,
~Skelleyman
Skelleyman is offline   Reply With Quote
Old 08-18-2012, 08:10 PM   #2
Rewards Points: 13,296
1-1/4 galzinized roofing nails.
Just make sure the brackets are slid up under the shingles and there's no exposted nails.
Old 08-18-2012, 11:15 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Yep. Make sure they're the HDD-Hot dipped. The EG will rust off in no time.
tinner666 is offline   Reply With Quote
Old 08-20-2012, 09:52 AM   #4
Rewards Points: 77
Thanks. Can't tell if these are dipped or not. http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Old 08-20-2012, 10:04 AM   #5
Pro Slate Roofer
tinner666's Avatar
Those are EG-Electro galvanized. Might as well be 'brights' for all the good EG does.
Old 08-20-2012, 10:06 AM   #6
Pro Slate Roofer
tinner666's Avatar
The ones you want are dull grey and look rough as a cob. If you can't find any, buy and use copper nails. 1-1/4" should be fine.
Old 08-23-2012, 12:12 PM   #7
Rewards Points: 77
Question: So I nail the bracket under the top shingle or outermost shingle. Won't that allow moisture through? Should I put a bead of calk underneath the nail head? Then give it that last hit?
Old 08-23-2012, 04:49 PM   #8
Pro Slate Roofer
tinner666's Avatar
The nails holding the shingles to the roof are supposed to be right directly under the edge of each shingle above it. They don't get caulked. You can if you want to though.
The Following User Says Thank You to tinner666 For This Useful Post:
Skelleyman (09-25-2012)
Old 09-25-2012, 09:19 AM   #9
Rewards Points: 77
Would these work?
http://www.sears.com/clothing_women'...4702P?prdNo=12
Thanks,
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 03:57 PM
Shingle over shake roof life expectancy JLD Roofing/Siding 2 10-12-2011 04:34 PM
Should I replace my roof? skittlebear Roofing/Siding 8 04-10-2010 07:01 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
