-   -   Secure SR clips to shingle roof (http://www.diychatroom.com/f9/secure-sr-clips-shingle-roof-154107/)
Skelleyman 08-18-2012 01:01 PM
Hello All,
I'm going to be installing some SR cable on my roof sometime between now and the fall to aid against ice damns. The cables I got come with good these metal clips seen here: http://www.radiantsource.com/cart/ca...t_detail&p=278 .What should I use to secure the clips to the roof? An adhesive of some sort, Id take recommendations or should I use tacks/nails? Whatever I get get at Home Depot or Lowes would be nice or if I need to order something online, I definately can as I've got time.
Thank You,
~Skelleyman
joecaption 08-18-2012 07:10 PM
1-1/4 galzinized roofing nails.
Just make sure the brackets are slid up under the shingles and there's no exposted nails.
tinner666 08-18-2012 10:15 PM
Yep. Make sure they're the HDD-Hot dipped. The EG will rust off in no time.
Skelleyman 08-20-2012 08:52 AM
Thanks. Can't tell if these are dipped or not. http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
tinner666 08-20-2012 09:04 AM
Those are EG-Electro galvanized. Might as well be 'brights' for all the good EG does.
tinner666 08-20-2012 09:06 AM
The ones you want are dull grey and look rough as a cob. If you can't find any, buy and use copper nails. 1-1/4" should be fine.
Skelleyman 08-23-2012 11:12 AM
Question: So I nail the bracket under the top shingle or outermost shingle. Won't that allow moisture through? Should I put a bead of calk underneath the nail head? Then give it that last hit?
tinner666 08-23-2012 03:49 PM
The nails holding the shingles to the roof are supposed to be right directly under the edge of each shingle above it. They don't get caulked. You can if you want to though.
Skelleyman 09-25-2012 08:19 AM
Would these work?
http://www.sears.com/clothing_women'...4702P?prdNo=12
Thanks,
