Sealing Three Tab Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-28-2008, 08:52 AM   #1
Sealing three tab shingles
Question:When you install three tab shingles and the weather conditions do not allow for enough thermal gain to heat the adhesive and seal it and you live in an area prone to high winds how do you get the tabs to seal? Do you put roofing cement under each tab, use some device to heat them? Thanks!
cheyenne is offline   Reply With Quote
Old 01-28-2008, 09:00 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,404
Ayuh,....
I Hope,+ Wait........
Hoping the Sun shines,..... Before the Wind blows......
Bondo is online now   Reply With Quote
Old 01-29-2008, 12:03 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
if you go back 20 years there were no sealants.tar line on the shingles,they just relied on proper nailing,if they`re nailed right ,it shouldn`t be an issue
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-29-2008, 01:41 AM   #4
Hello,
I agree with TRG, but in Alaska we do use Henry's mastic if the job calls for it. A quarter size dab under each corner of the tab.
Keith
roofboy is offline   Reply With Quote
Old 01-29-2008, 07:18 AM   #5
Thanks for the replies. I'll go with the mastic if I see any lift problems.
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 05:53 AM
Falling shingles!! sk8z Roofing/Siding 14 12-11-2007 09:21 PM
shingle over??? lemeno Roofing/Siding 12 12-01-2007 11:39 PM
Does GAF still make 40yr shingles? Marlin Roofing/Siding 8 10-07-2007 12:49 AM
Solar Shingles? CuCullin Roofing/Siding 2 09-21-2007 08:11 AM
