Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-03-2011, 04:57 PM   #1
Sealing the roof from the attic
My roof is leaking about a foot from where it meets chimney. I went in the attic and saw that they put 1x2(or something similar) horizontally on the rafters and then put the sheetings on them. I now know exactly where it's leaking from but my fear is that perhaps the water is coming from way top of the roof, getting under the shingles but the underlayer paper is good till around chimney and that's where it enters the attic. I will use rubber coating over the shingles.
With that being said, is there any preferable product that I can use to close the thin gap between 1x2s from the attic? I could spray-foam but I'm not really trying to stop the air draft. Anybody has suggestions?
Korkmaz is offline   Reply With Quote
Old 12-03-2011, 06:37 PM   #2
Moderator
kwikfishron's Avatar
Spray foam and rubber will not fix your leak.
More than likely you have an issue with the chimney flashing and it’s just entering the attic a foot away. But since nobody here can see what you’re seeing then posting a picture of the roof and chimney would help.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Windows on Wash (12-03-2011)
Old 12-03-2011, 07:20 PM   #3
I'll try to take a pic tomorrow and post it. If it is the flashing, I can't put a layer of rubber coating starting from the bottom foot of the chimney to about 3' away, kind of like a wide rubber skirt around chimney?
Old 12-03-2011, 07:25 PM   #4
Two choises, fix it right or have it keep leaking and take out the roof sheathing, sheetrock and insulation below.
The is no way a roof leak of any kind can be fixed inside an attic.
By the sounds of your questions you need a roofer to take a look at this not you.
Old 12-03-2011, 07:32 PM   #5
Moderator
If you want to “solve” the problem then post some pictures. How to attach a photo to a post
At this point all I can guarantee you is that there will be no rubber involved is repairing your shingle leak.
-NEW MEMBERS-
Old 12-03-2011, 07:53 PM   #6
Ok. Here is the pic. As you see, the flashing is covered with the rubber stuff. I did it I believe a month ago. But I think it needs to cover a lot more, rather than just the bottom of the chimney. (I thought at least)
Old 12-03-2011, 08:25 PM   #7
Moderator
What you need is a knowledgeable roofer to build a cricket behind the chimney and rework the flashing.
Thanks for the after dark pic btw.
-NEW MEMBERS-
Old 12-03-2011, 09:40 PM   #8
I see. Thanks for the advise. So you think the water is building behind the chimney, then running to the corner and going in the attic that way? I see how a cricket would prevent the water build-up behind the chimney but it seems like it'd direct the water where it enters the attic again.
Old 12-03-2011, 10:29 PM   #9
RFN-4A-LVN
Roofmaster417's Avatar
What you need is 1.New Roof,2.Cricket,3.Some new counter flashing..,.,Pretty much in that order.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
seeyou (12-04-2011)
Old 12-04-2011, 07:32 AM   #10
old guy contractor
tcleve4911's Avatar
4.)....and stop getting tar goop and caulking all over the place...
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
seeyou (12-04-2011)
Old 12-04-2011, 07:44 AM   #11
What a mess, that roof should have been replaced 5 years ago. and the chimmney should have been tuck pointed, not smear tar all over it. Good luck trying to get it off now so it can be fixed correctly.
Old 12-04-2011, 08:54 AM   #12
Pro Slate Roofer
tinner666's Avatar
That roof is shot and only a new roof will fix your issues. And quit spreading that stuff on it. It'll only increase the cost of a new roof.
Frank
tinner666 is offline   Reply With Quote
Old 12-04-2011, 12:09 PM   #13
Exterior Construction
Windows on Wash's Avatar
Come on tinner....have you not seen this stuff?
No, in all seriousness...you need a new roof. It is time.
Old 12-04-2011, 12:42 PM   #14
"Nail-Bender"
Come on "Win on W"!
Can't I just spray that stuff all over my roof and it will be fixed!!!
The TV says it fixes any leak problems!
You don't believe the TV?!?
Thanks-
RF
rossfingal is offline   Reply With Quote
Old 12-04-2011, 07:34 PM   #15
Thank you all for your inputs. I am aware that we need a roof. However, I was just looking for a temp solution. My daughter will be out of daycare in a year and then we'll be able to get a new roof. I'm also glad that I found out about "cricket". We'll need 3 of those. It's a civil war house with 32 sq. Roof and the lowest price I got was $7,500 "if I take out the shingles and replace the necessary sheeting". Btw, I did use 2 cans of that flex-seal. :D I'll go ahead and use a little more tar since it probably won't get any worse and I know exactly where it's leaking. But we'll get the new roof next year and it'llbe a huge relief. Thank you all again.
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
12-6 roof trusses, finish attic? chipraynor Building & Construction 0 03-10-2011 07:41 PM
Attic fan options. P550 Electrical 6 08-22-2010 01:30 PM
Attic Insulation on Roof MrSafety Roofing 2 06-13-2010 11:48 AM
Frost in the Attic 295yards General Discussion 13 12-07-2009 05:27 PM
