Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-08-2011, 02:59 PM   #1
Question
SEALING and INSULATING flat tiled roof
I have a flat tiled roof with slight run off to central point
I'm in the process of insulating the walls with xps extruded foam blocks covered with armoured neting and mortar.
I now want to extend the insulation project to include the roof.
I need the roof to be transitable, so I'm drawn away from using a combination of vapor barrier, xps foam and outer ashfalt barrier on top?
I recently heard about some spray on type of cement foam which both seals/insulates the roof and it is more transitable?
I would apprecaite some input/Advise/Options
smileibiza is offline   Reply With Quote
Old 12-08-2011, 06:41 PM   #2
Exterior Construction
Windows on Wash's Avatar
A picture and better description will illicit more of a response from most folks. We need a bunch more details.
Old 12-09-2011, 09:52 AM   #3
Low Slope Roofing
Agreed, lots of pictures.
1985gt is offline   Reply With Quote
Sealing or insulating attic fan Blondesense Building & Construction 11 12-12-2009 03:39 PM
