Sealing flat roof edge
You should ahve a field sheet laid to the deck, the perimeter metal, then an additional strip of roofing membrane to seal it all up.
I would not use the "gravelled tar paper" route though.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
