Sealing Closed Cut Valleys - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-03-2008, 04:10 PM   #1
Sealing closed cut valleys
Hello, I am just about finished roofing my house. I used laminated 30 year shingles and membrane in the valleys. I've used Henry roofing cement around the flashings and roof penetrations. However, I was wondering if it would be better to use a 100% silicon caulk on the cut edge of the shingles in the valley, or continue to use the black roofing cement. Opinions?
tranman is offline   Reply With Quote
Old 10-03-2008, 05:21 PM   #2
Also
Because of the heat, the majority of the shingles have sealed. Should I try to pry them up, or just leave the whole thing alone? I have not applied any cement or sealant to the valley cut.
Old 10-03-2008, 05:56 PM   #3
if its all sealed,leave it alone.
johnk is offline   Reply With Quote
Old 10-03-2008, 05:58 PM   #4
Residential Roofer
Slyfox's Avatar
Instead of lifting the shingles individually, simply lift them several at a time 'lifting gently from the cut edge' and place your 'roof cement' under far enough so it's not visible,
never use silicon under or in between shingles, it's not compatible and will never fully bond to the shingles and will prevent the shingles from re-bonding to each other.
In my area 'Youngstown, Ohio' we seldom run sealant down the closed cut valleys unless the slope of the roof is leass than a 4/12,
so depending on where your located and how teep the roof is, you may not need the sealant if you properly installed the valley.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 10-04-2008, 11:48 PM   #5
Doing This Way Too Long
Rewards Points: 532
Yeah, what the canuck said.
OldNBroken is offline   Reply With Quote
Old 10-05-2008, 09:05 PM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Yeah, sounds like it's too late to fix now.
tinner666 is offline   Reply With Quote
Old 10-07-2008, 05:22 PM   #7
Thanks for the help. I will try to spot seal with roofing cement where I can. We had a pretty good rainstorm the other day and I did not notice any obvious leaks.
Old 10-07-2008, 06:32 PM   #8
That really shouldn't be necessarry to do.
Ed
Ed the Roofer is offline   Reply With Quote
Carrier furnace giving r-w closed error? mel189 HVAC 7 11-27-2008 09:59 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
Expansion Valve Stuck Closed JustinD HVAC 3 08-31-2007 04:59 PM
Valleys' water over-flowing gutters davco Roofing/Siding 2 06-11-2007 08:15 AM
Bathtub Drain partially closed??? Sellncars Plumbing 3 08-14-2006 12:43 PM
