Sealing Along Chimney Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-27-2012, 01:43 PM   #1
Rewards Points: 93
Sealing along chimney flashing
Hi all, I'm doing some per-winter caulking and have a question about this flashing. Should the existing caulk extend all the way to the shingles? What about between the gutter and chimney? Also, should i put a vertical line of caulk along the fascia cover next to the chimney? I'm trying to seal mice out but don't want to block any water drainage paths.
Sealing along chimney flashing-image-1656496783.jpg   Sealing along chimney flashing-image-2310340866.jpg
scottyv81 is offline   Reply With Quote
Old 10-27-2012, 01:47 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Don't caulk the bottom of the flashing to the shingles. It shouldn't cause a problem to caulk the other items you mentioned.
seeyou is offline   Reply With Quote
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 09:22 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Need help deciding giving this chimney flashing contractor a second chance tracyj Roofing/Siding 3 03-29-2011 10:56 AM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
