Sealer Over Modifed Bitumen ? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-06-2010, 03:00 AM   #1
Sealer over modifed bitumen ?
I bought this house in April 2010, It appears to have a fairly new patio roof. I suspect it was replaced in 2008 due to Hurrican Ike. the modified bitumen sheets. There are some mildew stains on the ceiling wood; apparently there was a leak at some point. In 7 months, there has been no signs of leakage. It does puddle slightly in the corresponding areas of mildew. I have some TPO from where a our offices were constructed. Should I just seal the roof and build up the areas where it is puddling with liquid bitumen or go ahead and lay down the TPO, Issealer recommended for the Modified bitumen ( MB ) ? Can I use TPO adhesive right over the modified bitumen. I will have to remove the drip edge to apply the TPO as whoever installed the MB, terminated the material flush with the edge of the patio, and as I understand it, the TPO would fold down and the drip edge mounted on top of that. Thanks. Kemah TX
Copperly is offline   Reply With Quote
Old 12-06-2010, 08:55 PM   #2
Tpo and mod-bit are not compatible
johnk is offline   Reply With Quote
The Following User Says Thank You to johnk For This Useful Post:
Copperly (12-08-2010)
Tags
advise needed
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 07:29 AM
concrete sealer on slate tile? the carpenter Flooring 1 03-28-2010 07:56 PM
Built Up Roofing (BUR) vs Modified Bitumen Roof (Torch Down) RacerX Roofing/Siding 4 01-31-2010 01:54 PM
Grout question poolecw Flooring 11 10-29-2008 07:32 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
