Sealant For Exposed Fastener Metal Roofing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-17-2012, 11:35 AM   #1
Rewards Points: 38
Sealant for exposed fastener metal roofing?
I have a small shed I am roofing with exposed fastener metal panels and a couple of the three foot wide panels will need to overlap with each other. Is it necessary to run a bead of some sort of sealant along the length of the two panels that I need to overlap? If so, can anyone recommend what to use?
dweeter is offline   Reply With Quote
Old 04-17-2012, 11:41 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,926
Use whatever the manufacturer recommends.
They should have some sort of indicated or approved material on the installation instructions.
If not, call them.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (04-20-2012)
Old 04-17-2012, 11:41 AM   #3
Rewards Points: 13,296
There's a bunch of differant styles of metal roofing you could be talking about.
Most need no sealers because the ridges over lap to prevent water from getting in.
Corragated and 5 V need no sealer.
Old 04-17-2012, 11:49 AM   #4
Rewards Points: 38
Thanks. The panels are Ameri-Drain style from ABC Metal Roofing. They have half-inch ribs every 6 inches.
Old 04-17-2012, 12:07 PM   #5
http://abcmetalroofing.com/panels_ameridrain.html
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
Adding panel insulation and metal roofing Ben gilmore Roofing/Siding 1 04-02-2012 08:24 AM
metal roofing nomoney Roofing/Siding 27 01-12-2009 10:29 PM
Metal Roofing for Experienced Beginners rezroofers Roofing/Siding 3 06-21-2007 12:42 AM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 10:59 PM
