Screws Or Nails For Aluminum Soffits/Fascia? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-29-2016, 06:00 PM   #1
Rewards Points: 20
Screws or Nails for Aluminum Soffits/Fascia?
I'm a homeowner planning on installing white aluminum soffits and fascia myself. I saw a YouTube video of a guy using square head stainless steel (I think!) screws to secure his aluminum. Is this a viable alternative to stainless steel nails?
I'll be doing most of the job without an assistant. It seems like using the square head screws and a cordless drill driver would be easier than trying to nail it up.
Any downsides to using screws? Are they driven in to where they just lightly touch the aluminum? Is 1 1/2" long enough?
joshhemming is offline   Reply With Quote
Old 03-29-2016, 07:20 PM   #2
Rewards Points: 646
Re: Screws or Nails for Aluminum Soffits/Fascia?
I regularly use 5/8" screws for soffit. They are labeled as soffit screws at the supplier, they aren't stainless but shouldnt get wet anyway.
I
PatChap is offline   Reply With Quote
Old 03-29-2016, 07:41 PM   #3
Rewards Points: 20
Thanks. Wow, I would have thought they'd be longer.
Do you use stainless screws for the fascia, since they DO get wet?
Do you put a couple of screws into the face of the fascia at the corner wraparound overlaps?
I
Old 03-29-2016, 09:00 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
Use stainless trim nails for the fascia. Get one of the drivers like the one I linked below. Makes it easy, it holds the nail and keeps you from hitting the fascia with your hammer if you slip. Just set the nails til they touch. Don't beat the heck out of them.
http://www.toolbarn.com/malco-tnp3s....ad=54712189574
Mike Hawkins
firehawkmph is online now   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
roofermann (03-31-2016)
Old 03-30-2016, 05:46 AM   #5
Rewards Points: 646
+1 on the stainless trim nails shot from a pea shooter.
Prepunch the holes with a siding punch as well.
On the screws, 5/8 is plenty long enough, as most soffit is around .019 thick. You can use the pea shooter for the soffit as well, but screws are a bit more user friendly.
Old 03-30-2016, 06:40 AM   #6
Property Mgt/Maint
Rewards Points: 1,258
good info here guys, anything visible gets pre-drilled (or punched), I do leave my SS nails just shy of flush. (maybe a 1/32) Just enough to 1.) not bend the alum out of shape by indenting, and 2.) keeps the hammer face of the metal.
Never tried the pea shooter but I am sure it would save the fingers starting those small nails.
Yodaman is offline   Reply With Quote
Screws vs Nails for deck. dabeast Building & Construction 10 10-28-2013 11:08 AM
Nails Vs. Screws For Ceiling Furring Strips emagsamurai Building & Construction 3 11-30-2012 02:57 PM
Screws or nails in dbl layer of OSB soggycashew General DIY Discussions 6 02-18-2012 01:38 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
