Screws For Corrugated Metal Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-25-2012, 08:04 PM   #1
PPBART's Avatar
Rewards Points: 307
Screws for Corrugated Metal Roofing
I'm going to be replacing the corrugated metal roofing on my workshop as soon as the material comes in. Will be using standard 26" wide corrugated (~2.5" waves). Question is placement of the screws -- original roofing was nailed with nails in the peaks of the corrugations, but I've been told the fasteners (I'll be using screw) should go in the valleys, closer to the framing and tighter. So do I put the screws in the valleys or on the peaks?
PPBART is offline   Reply With Quote
Old 10-25-2012, 08:13 PM   #2
Rewards Points: 13,300
Only the high spots, 20 screws per panel on a 10' panel.
Old 10-25-2012, 08:21 PM   #3
funfool's Avatar
Rewards Points: 534
The valley. I suggest you look at the manufacturer recommendations for installing.
I know, I hate reading the manual also.
Will be screws with rubber washers you install it with.
Main concern is flat framing in proper location to screw it to and spacing of the screws, and how far apart you need to run stringers to screw to.
If you remove the old metal roofing and find it was installed over osb sheathing, is no problem, just install new metal and screw it down as suggested in the instructions.
But nailing through the ribs is a home owner diy that thought he knew what he was doing. He was wrong.
funfool is offline   Reply With Quote
Old 10-26-2012, 08:45 AM   #4
PPBART's Avatar
Rewards Points: 307
Originally Posted by funfool View Post
...installed over osb sheathing, is no problem, just install new metal and screw it down as suggested in the instructions...
No sheathing, just 1x6's on ~2' centers across rafters.
Old 10-26-2012, 09:34 AM   #5
I went on three differant manufactures web sites that make corrigated roofing and looked at there install directions.
All suggested fastening on the high spots not the valley.
Old 10-26-2012, 01:58 PM   #6
PPBART's Avatar
Rewards Points: 307
Here's a link to instructions from Union Corrugating Company:
http://www.unioncorrugating.com/docu...stallation.pdf
See figure 1 -- puts screws in valleys at eave, on ridges for intermediate fasteners(!)
Old 10-26-2012, 02:27 PM   #7
Screws in the peaks
[I'm going to be replacing the corrugated metal roofing on my workshop as soon as the material comes in. Will be using standard 26" wide corrugated (~2.5" waves). Question is placement of the screws -- original roofing was nailed with nails in the peaks of the corrugations, but I've been told the fasteners (I'll be using screw) should go in the valleys, closer to the framing and tighter. So do I put the screws in the valleys or on the peaks?[/quote]
Go into the peaks and use longer screws with rubber washers. The washers won't last very long but are better than not using anything. And don't over tighten. Peaks over valleys because you should try to keep the fasteners away from water. Where's more water? In the valleys. Plan on going back up every couple years to re-screw down the screws due to the metal expanding and contracting. That natural effect of heating and cooling will eventually work the screws loose.
augie1684 is offline   Reply With Quote
Old 10-26-2012, 02:41 PM   #8
funfool's Avatar
Rewards Points: 534
All the metal roofing I have installed is coloured roofing on homes, it has flat spots in the valley and perfect place to fasten it.
And I use 2 length of screws while installing it. Longer screws in the valley to fasten it to the framing, while short screws where the ridge over laps.
In a 3' wide piece, will be 3 screws in the valley holding it tight to the framing, the short screw on the overlap, I do not want to reach the framing, just tie the two pieces of metal together. So the wind can catch the lip.
My concern with screwing it on the peaks, I am using a 18 volt makita screw gun, Going to take a real light trigger finger to snug the screws with out sucking down and distorting the shape of the metal. I want to screw it to the framing in the places the metal sits flat on the framing. So short screws for the overlap, do not want to reach the framing.
Your real concern on a metal roof is the flashing. will be some that gets installed before the roof panels go down, some after.
Depending on your roof, as to what flashing you need, not uncommon to need 4 different styles of flashing, sometimes will need to have some made up to work for that job.
Just thinking, no sense in over thinking the screw pattern, your manufacturer will tell you. The key to a metal roof that does not leak is the flashing.
All of this depends on the finished look you want.
A $300k home, it needs to look nice, A chicken coop in the back yard, a little more flexibility.
Old 10-26-2012, 07:38 PM   #9
Pro
R-panel roofing is screwed in the flat (valley) area. If you screw through the peak, it's got nothing backing it up, so the metal will flex. I'd screw it down into the rafters.
With the screws to fasten two panels together, you're not going to compress the peak since you're only screwing the two panels together.
smalpierre is offline   Reply With Quote
Old 04-08-2014, 04:11 PM   #10
Funfool is right - follow the manufacturer's guidelines if you are at all concerned with performance or warranty coverage. Nailing the metal panels on the peaks will distort/ bend the metal around the screw. Even if you manage to attach the panels without any kind of distortion, the next windy day you have, you may start seeing warpage around the peaks and screws.
lawrence.crush is offline   Reply With Quote
Old 04-08-2014, 07:28 PM   #11
Rewards Points: 79
If you want a warranty the only thing that matters is the manufacturer installation requirements. If you don't care about that then do what you feel like. Fastening through the ridges is better for keeping water out but harder to keep the metal from distorting. Fastening through the valleys is worse for water but looks prettier.
eclark is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 08:34 PM
Meridian Metal Roofing Arky217 Roofing/Siding 1 12-07-2010 06:33 PM
Loose sheet metal screws harrysanders Building & Construction 4 05-30-2010 09:16 PM
Best way to seal new Chimney through Metal Roofing tuchodi Roofing/Siding 5 03-01-2010 10:45 AM
