Screw Down Roof. Can I Use Liquid Nails Too? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-18-2007, 11:29 AM   #1
screw down roof. Can I use Liquid Nails too?
I have a bunch of screws backing off in my screw down metal roof. I was going to go back in with either one gauge larger or perhaps just longer same gauge screws. However, I was wondering if I could add some liquid nails or whatever adhesive to the thread to maybe help prevent backoff in the furture. Or am I just wasting time?
Any thoughs are appreciated.
aberezin is offline   Reply With Quote
Old 11-18-2007, 06:06 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Use a good caulk like NP1 and set the screw gun to 1-2 so you don't over-compress the washer.
If it won't drive at that setting, move up a level until you fing the minimum torque needed.
tinner666 is offline   Reply With Quote
Old 11-18-2007, 06:45 PM   #3
Thanks, Ill give it a try
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Protruding nails through exterior patio roof miami789 Roofing/Siding 7 06-25-2007 03:42 PM
rust on nails in attic on one side of roof only this old house Roofing/Siding 3 01-27-2007 10:56 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
