Sanding Hardi Panels - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-26-2013, 09:25 PM   #1
Rewards Points: 91
I have some beat up hardi panel and trim on the outside of my house, and was wondering if it is ok to sand this stuff (besides the hazard of breathing it). I want to even out some spots that are fraying re-prime and paint.
no_Wedge is offline   Reply With Quote
Old 07-26-2013, 09:36 PM   #2
Rewards Points: 12,808
Should be fine if you wear a dust mask.
Posting some pictures so we can see just how bad it is would be nice.
If it's falling apart where there's end cuts it's because someone did not prime and paint it as should be.
Also if it was installed any closer then 2" to any solid surface EG; roofing, grade, deck, stoop, it's going to fail.
Old 07-27-2013, 03:06 AM   #3
roofingquotes's Avatar
Be sure you watch some safety precautions before doing it.
roofingquotes is offline   Reply With Quote
Old 07-27-2013, 07:17 AM   #4
If there's really low areas then use a filler to level it out, then sand it.
Bondo is one filler that works.
Neutral path between two main panels EMiller Electrical 13 03-17-2014 08:48 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 09:43 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 09:26 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
