-   -   Sanding Hardi Panels (http://www.diychatroom.com/f9/sanding-hardi-panels-184310/)
no_Wedge 07-26-2013 09:25 PM
I have some beat up hardi panel and trim on the outside of my house, and was wondering if it is ok to sand this stuff (besides the hazard of breathing it). I want to even out some spots that are fraying re-prime and paint.
joecaption 07-26-2013 09:36 PM
Should be fine if you wear a dust mask.
Posting some pictures so we can see just how bad it is would be nice.
If it's falling apart where there's end cuts it's because someone did not prime and paint it as should be.
Also if it was installed any closer then 2" to any solid surface EG; roofing, grade, deck, stoop, it's going to fail.
roofingquotes 07-27-2013 03:06 AM
Be sure you watch some safety precautions before doing it. :wink:
joecaption 07-27-2013 07:17 AM
If there's really low areas then use a filler to level it out, then sand it.
Bondo is one filler that works.
