The Sales Ad. Didn't Mention The House Comes With A Pool - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-07-2010, 04:31 PM   #1
Rewards Points: 87
The sales ad. didn't mention the house comes with a pool
Not until I had the house inspection ... a 2" deep pool is found on top of the patio's flat roof. I can't swim in here so I decide to remove the pool by installing a drain/downspout and connect it to the existing downspout as seen in the picture (top right corner) ... is this a good solution ? Any suggestion in specific flat roof draining system? Thank you.
The sales ad. didn't mention the house comes with a pool-p1140206-medium-.jpg
Stephen S. is offline   Reply With Quote
Old 01-07-2010, 04:36 PM   #2
There has to be drainage somewhere...I hope ?
Probably clogged up with leaves etc ?
Old 01-07-2010, 04:37 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 138
That's actually quite impressive LOL. It was not leaking anywhere else to drain? At least you know the roof is quite solid if it can handle all that water lol. But yeah I would definably hook it up to the downspout. Maybe even give it a dedicated downspout, I would go as far as using PVC and draining it far enough away from the house. (at least a few feet if the ground slants away)
Old 01-07-2010, 04:39 PM   #4
Before hooking up to that one specific downspout, ensure that is the low point of that flat roof and also as Dave had mentioned, check for an existing clogged drain location if one exists that you can not see.
Use a sump pump to remove the water first and then see where the low spot is where water lastly remains.
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-07-2010, 04:42 PM   #5
may have been self draining epdm now sagging. if there's a downspout in there time for scuba to suit up
Old 01-07-2010, 05:30 PM   #6
Rewards Points: 87
Nope ... no drainage at all ... and it'll leak after heavy rain that the water level go past the metal flashings (is that the correct name?) at the four sides... quote from the inspection report: "water pond on flat roof and will only disperse by evaporation" ...
but no good sunlight in seattle for a while :P
Old 01-07-2010, 06:40 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
is there ever any good sunshine in Seattle? I see the typical moss growing in the shingles.
at least the inspection report did note it. That settles the problem of a failure to disclose.
It looks like there is merely a deck under this. Is that correct? Anyway, plug a drain in it once you find the low spot but what is more concerning to me is where it attaches to the main roof. That will allow the water flow to be held up and depending on how the roof is built, this could cause water to be able to get to the roof boards and even inside the structure.
that area should have either had epdm wrapped from over the flat roof side up under the shingles to a height that would not allow retained water to ever be higher that that point.
either that or the roof should have been built up so as to prevent that dam from the flat roof sidewall.
Old 01-07-2010, 11:36 PM   #8
Wire Chewer
Rewards Points: 138
Looking at that again, if you add a railing that would make a nice little skating rink when it freezes LOL.
Not every day do you see people playing hockey on a roof.
Old 01-11-2010, 08:24 AM   #9
Licensed Engineer
Rewards Points: 175
Hidden roof damage??
It looks as if the water has risen to a level where it may already be leaking up under the flashings, then saturating the roof decking and maybe framing lumber.
I would get the water pumped off, than have the same inspector take a second look at the roof over the patio.
If you go through with the purchase you should install some metal strips that are toxic to moss (either copper or zinc) under the shingles of the main roof near the ridge. The rain water run-off passing over these strips will pick-up enough of the soft metal strips to prevent the growth of moss on the lower shingles.
MI-Roger is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Just bought a house, used to be meth house acerunner General DIY Discussions 7 12-16-2009 02:10 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 04:05 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 07:51 AM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 08:41 PM
