sagging roof and ceiling
here is the problem, the roof and the ceiling have a 4 inch drop over our 2car garage. Stick built. I am thinking of building 2x12 beam to go under the ceiling joist and jacking it all back up or purchasing 4 or 6inch steel H-beams and doing the same jacking. what do you think? thanks
ron |
Secondly - To jack up the ceiling joists of the garage will not raise the roof's sagging ridge beam if it is a typical framed garage structure. See illustration below: http://qcfocus.com/files/Collar%20Tie.JPG (Illustration found on qcfocus.com) |
Can you post photos of the exposed joists and rafters?
I don't see any structural damage, the rafters and joist are 2x6, stick built truss. I have placed a jack under one joist and pushed it 2 inchs of the 4 and could notice a difference on the roof line. but this only pushed one of the 24' span.
Again, you will be able to raise the ceiling, but the roof's ridge beam will unlikely raise with it..... Just realize that a 4" drop is a considerable sag. There will be alot of stress placed on the already sagging joists....... jacking these up....You could split some of the joists in the process..... |
| All times are GMT -4. The time now is 03:22 AM. |
