Sagging Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2013, 06:33 PM   #1
Sagging Roof
I've agreed to terms on the purchase of my first home pending inspection. The obvious issue with the home is that the roof ridge is sagging. I am planning on having a professional roofing contractor inspect the roof. Is this always a significant issue? It definitely appeared that there were a few layers of shingles and I live in Northern Ontario Canada, so I imagine snow weight wouldn't help. The other realtor has said that there is no access to the attic from inside the house and there doesn't appear to be any gable vents either so I'm worried it will even be possible to adequately inspect it.
Any thoughts on this from anyone with similar experience?
Cheers
Last edited by kwikfishron; 08-25-2013 at 06:46 PM. Reason: added the picture to the post
Matto29 is offline   Reply With Quote
Old 08-25-2013, 08:28 PM   #2
Rewards Points: 13,276
Unless there's a cathedral style ceiling in the US by code there has to be an access to the attic area.
Unless that seller was willing to let me cut a hole and check it out I'd pass.
Even then to fix it right involves removing the whole roof and rebuilding all the rafters and ridge pole.
There is no lifting it, only stabilizing it without a total rebuild.
Old 08-26-2013, 10:39 PM   #3
Got the seller to agree to putting in an access in the master bedroom closet. Sending in an expert on Wednesday to check things out. Thanks for your help!
Old 08-26-2013, 11:48 PM   #4
Rewards Points: 2,210
Here in canada there did not need to be an attic access if the ceiling to peak height was under a certain height (Sorry the measurement eludes me)
Also some homes that were built modular (2 or more pieces put together) did not have attic access.
My wild guess is looking at the age of the house it was stick framed with just 2x4 rafters and they have sagged and some may be even broken. Can be fixed.
mae-ling is offline   Reply With Quote
Old 08-27-2013, 08:31 AM   #5
PoleCat's Avatar
Rewards Points: 1,646
I would have checked if getting a peek through the turbine vent was feasible.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
mae-ling (08-27-2013)
Old 08-27-2013, 08:58 PM   #6
An old Tradesmen
Rewards Points: 6,516
Moved to roofing forum.
Old 08-28-2013, 08:51 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,874
That thing looks scary from the pictures. Best to get an inspector (preferably one with some real framing knowledge) look at it.
The Following User Says Thank You to Windows on Wash For This Useful Post:
joecaption (08-28-2013)
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Sagging Roof nayak143 Roofing/Siding 15 06-12-2009 02:03 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 12:17 PM
fixing a sagging porch roof vhowler Roofing/Siding 2 05-11-2006 08:53 PM
