Sagging Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-05-2011, 08:04 PM   #1
Sagging Roof?
Is it an illusion when your looking at your roof and it looks like it's sagging
towards the middle? Or should I be concerned and inspect the underside
from the attic?
BlaJoRon is offline   Reply With Quote
Old 11-05-2011, 08:22 PM   #2
Rewards Points: 1,574
Hold an envelope or index card in your line of vision to align with the roof; it should help you see if it is an actual or some visual illusion.
How old is the house?
If it is sagging, it could be a bad thing (rot, undersized rafters, etc...).
bob22 is offline   Reply With Quote
Old 11-05-2011, 08:29 PM   #3
Residential Roofer
Slyfox's Avatar
Sagging happens quite often during the settling process of a structure, especially in the old stick framing of homes, not so much in homes with trusses.
More often then not it's nothing to worry about, and usually isn't enough of an eyesore to justify the cost of leveling it out.
I would for sure take a look from underneath "in the attic/crawl space" just to make sure.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 11-06-2011, 08:18 AM   #4
I don't have any idea of how old the house is. The oldest date I've found is a dog license from 1968 in the basement, so it is at least that old.
Old 11-06-2011, 08:20 AM   #5
Okay, so poke my head up in the attic and I should be able to see the supports for the roof or the trusses or whatever?
Old 11-06-2011, 08:43 AM   #6
kwikfishron's Avatar
Rewards Points: 188
Post some pictures so we can see what your talking about.
kwikfishron is online now   Reply With Quote
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Sagging Roof nayak143 Roofing/Siding 15 06-12-2009 02:03 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 12:17 PM
fixing a sagging porch roof vhowler Roofing/Siding 2 05-11-2006 08:53 PM
