Sagging Roof On A 1.5 Story House - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-19-2009, 11:44 AM   #1
sagging roof on a 1.5 story house
Hi guys
This is actually my first post here, I've been living in my house for the past three years, it was built in the 40s. its a 1.5 story house. I havent had any problems with it, however I did notice that the roof sags quite a bit. When standing outside and looking at it from an angle, from one end to the other end, it probably sinks a good 4 inches in the middle.
Should I be concerned about this, should I try to fix this, or have it fixed. I have seen in other posts where people strengthen their roof by adding additional beams in the attick, however the problem is that, because my house is 1.5 stories, the second floor is built into the roof, my attick space only represents one third of my roof.
Any ideas on how this can be fixed without having to demolish anything in my upstairs rooms?
Thanks for any help
rootdown003 is offline   Reply With Quote
Old 02-19-2009, 11:30 PM   #2
Doing This Way Too Long
Rewards Points: 532
I'm guessing you have 2x4 rafters then. Without a visual we can only give you ideas. The outer walls of your finished rooms upstairs are what support those rafters. Do you know when the upstairs was finished? Either it has settled since it was finished, which you would notice inside the house. Or more likely the roof was already sagging when the upstairs was finished and the person finishing it didn't think to jack up the rafters BEFORE he built your outer walls underneath it.
Sorry, I can't think of any easy way to fix it after the space is complete. The good news would be that it shouldn't get any worse though.
OldNBroken is offline   Reply With Quote
Old 02-20-2009, 09:36 AM   #3
I'm really a noob here, so im not even sure what rafters are, I can tell however that those outer supporting walls are 2X4
The second floor was finished when the house was built in 1944 (plaster walls and all), I'm guessing it wasnt warped when they built it in 1944, this leads me to believe that warp happened over the years very gradually, maybe heavy snow falls didn't help either. it also makes wonder if it could continue to get worse
I guess jacking up the supporting walls now, would probably create all kinds of cracks.
Old 02-20-2009, 09:46 AM   #4
Rafters are the beams that go up to the peak to support the roof
You may not have the main beam that the rafters rest against
In some cases the rafters merely meet at the top
Outer walls as 2x4 is normal
Where is the sagging, in the middle of the roof?
Or along the edge of the roof?
In some cases roofs were built with the rafters 24" apart instead of the more normal 16". This can cause sagging too
Old 02-20-2009, 09:54 AM   #5
I'm at work right know, so I can't check, but I'm preety sure that the rafters are atleast 2X6 and their is a main beam, however it is quite thin I think only one inch thick.
The sag is gradual, from the one end, to the middle where it is the deepest
i'll have to check the spacing of the rafther, from memory I think it is 16 inch.
Old 02-20-2009, 11:15 AM   #6
A thin main beam is OK, its just to tie the rafters in
The rafter sizes depend upon how far they span
You actually do not measure the length of the rafter
You measure the distance from the center beam to the inside of the outer wall
So you measure along the writing "Rafter Span" in the figure
A 2x6 is good for almost 10', depending upon type of wood
2x8 is 13" 6"
2x10 is 17' 5"
I usually use a 2x10 as a min unless its a real short span
We can get some heavy snow every now & then
Old 02-20-2009, 12:07 PM   #7
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
What is actually sagging? Is it the ridgeboard or the roof itself as depicted in Scubadaves previous post (#4)?
To me it sounds like the ridge is sagging which would imply that your walls are spreading because the collarties or ridgebeam are inadequate.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Concrete roof on house... problems!! flipjarg Roofing/Siding 6 01-24-2009 11:06 PM
My roof is sagging - Correct Course of Correct Repair? young-jennifer Building & Construction 5 12-15-2008 08:59 PM
Thinking of Buying house with Flat roof lpcon Roofing/Siding 3 08-19-2007 09:23 PM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 05:16 PM
