Safety Harness On Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-01-2009, 09:02 PM   #1
Rewards Points: 150
safety harness on roof
I don't remember where, but I have seen in the past some people use safety harness when they work on a sloped roof.
Does anyone know how this is possible? does someone need to install something on the roof to make it happen?
-gramps416
gramps416 is offline   Reply With Quote
Old 07-01-2009, 09:22 PM   #2
Home Depot sells a complete kit for $100
Anchor point is secured across the ridge
I'm sure there are other methods
Old 07-01-2009, 09:40 PM   #3
We use them all of the time, in addition to safety boards using 2" x 6"'s locked into roof brackets.
Here is one link, nobody in particular.
http://www.snugharness.com/Roofing-Kits/
The Miller Brand seems to be one of the more common and popular units sold.
http://www.snugharness.com/Miller-Fall-Protection/
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-01-2009, 09:52 PM   #4
Pic of one being setup
Old 07-01-2009, 10:22 PM   #5
Thats the GOOD kind of bracket too, because you can reuse it over and over again.
Ed
Old 07-01-2009, 11:09 PM   #6
Registered User
Rewards Points: 5,180
If it is for your own house, this one installs permanently and comes with a plastic boot cover against water leakage. I've install about 60 of them, can go over or under the sheathing. http://www.superanchor.com/application.html Be safe, G
Old 07-02-2009, 07:11 AM   #7
They are required by OSHA, for roof workers, and not a bad idea for DIY'ers. You will likely not survive a fall from a roof, undamaged, even once.
Old 07-02-2009, 11:23 AM   #8
Rewards Points: 150
what makes one of these brackets permanent?, or better yet, how can you tell the difference between the disposable type and the permanent?
Which type is the one in the pic shown?
And finally, to install a permanent one, does it have to be done before the roof is installed?
-gramps416
Old 07-02-2009, 12:43 PM   #9
The link provided is to a permanent one
The shingles are then installed over the barce/attachment point
Then as stated there is a rubber boot that goes over it to help keep water out
I imagine it could be retrofitted if you have some extra shingles
The "temp" one is screwed in as you roof, then removed before you finish - to then be used again on the next roof
I have a cupola going on my roof
So I am going to attach some eye bolts all the way thru for any possible future needs
Old 07-04-2009, 11:18 AM   #10
Rewards Points: 150
one final question about this topic.
I have been finding a permanent solution that is a little different by the miller company"
http://www.millerfallprotection.com/...of_Anchors.pdf
that has single and double d solutions (apposed to their claw line)
has anyone used the single or double d's? to they have to fold over the ridge to install them? or not necessary.
thanks
-g416
Old 07-04-2009, 09:40 PM   #11
Looks like they don't have to fold over the ridge (unless the double D)
There are single "D's" that can be mounted on each side
I used my climbing gear harness & rope again
I'm 10' up the slope of the roof & 2 big 30x55 skylights are in
So looks like I'll be bringing the harness setup back
Old 07-05-2009, 02:47 PM   #12
That energy absorbing fall protection is another thing. I didn't get it, but then I cut tree branches from a ladder while the ladder is strapped to the tree and I am strapped to the ladder. No distance to fall.
Old 07-05-2009, 10:19 PM   #13
Unless the tree is hollow & falls when you cut a big branch
Had a friend tell em about that problem...after I cut a big branch off a tree out back & the whole tree swing as the branch went
I actually use my sawzall now to cut limbs
Easier to repalce a blade if it gets stuck
And less $$ to replace then my chainsaw
Old 07-06-2009, 12:50 PM   #14
Yes, every book I read and video I saw on cutting trees began with "In memory of. . ."
Haven't yet bought a Sawzall.
Old 07-06-2009, 05:16 PM   #15
tree cutting is another one of those tasks that looks easy when the experienced guy is doing it.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
