saddle roof
You already have your answer in the post title.
A carpenter should build the saddle so the water is directed away from the wall. At the same time I like to install ice and water shield wherever my sloped roofs meet walls. I would definetly do it in this case, in addition with meal step flashings, because water will be blasting that wall.
-Grumpy
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
