Rust On Vinyl Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-15-2013, 12:47 PM   #1
Rust on vinyl siding
The pretty yellow/tannish colored vinyl siding has a rust stain from a dripping hose bibb. Can rust stain be removed? If I replaced the length of siding, how do I cut a hole into siding piece for the bibb? Please tell me I can get the stain off.....
ol rick is offline   Reply With Quote
Old 06-15-2013, 05:40 PM   #2
kwikfishron's Avatar
Rewards Points: 762
Scroll down to the bottom of this link. http://www.vinylsiding.org/aboutsidi...main/cleaning/ I'd be curios of your results.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
ol rick (06-24-2013)
Old 06-16-2013, 12:58 AM   #3
roofingquotes's Avatar
You need a pressure washer to be able to remove the rust and a good cleaning solution helps in removing the rust. Just put the cleaning solution in the pressure wash and then start spraying.
roofingquotes is offline   Reply With Quote
The Following User Says Thank You to roofingquotes For This Useful Post:
Old 06-16-2013, 07:53 AM   #4
Rewards Points: 13,960
Get a bottole of "The Works". Any Dollar store, Wal-Mart, grocery store will have it in the clean supply area.
Spray it on, let it sit about 1 Min. and hose it off and the stain is gone.
Pressure washing is a waste of time on a rust stain.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
Gymschu (06-16-2013), ol rick (06-24-2013), roofermann (08-18-2014)
Old 06-24-2013, 04:53 PM   #5
Question
Rust stain remover
OK - I had a bottle of Wink rust remover, tried it on the vinyl siding but it did not work. Joe Caption, I know about The Works toilet bowl cleaner but I did not know The Works made a rust stain remover. Is this a new product?
Old 08-17-2014, 07:20 PM   #6
Yes! The Works Toilet Bowl Cleaner worked and removed about 95% of the rust stain on the vinyl siding. Thanks.
The Following 3 Users Say Thank You to ol rick For This Useful Post:
Fix'n it (08-17-2014), nissanman (07-16-2016), oh'mike (08-18-2014)
Old 08-18-2014, 12:29 AM   #7
I believe "The Works" toilet bowl cleaner is basically just Hydrochloric Acid, also known as Muriatic Acid, Concrete Cleaner, and is also sold as pH adjuster for swimming pools.
The problem with hydrochloric acid is that it eats almost everything except plastic..
Make sure to use plenty of water to wash it away.. Maybe even some baking soda as it can eat right through concrete and brick very easily.
A safer solution would be to use Phosphoric Acid.. also found in Naval Jelly and many automotive chemical type rust removers. The phosphoric acid turns the iron oxide into Iron Phosphate.. it literally vanishes in front of your eyes.
I make a home made solution of it for my wife to use in the shower to get rid of the rust stains.. She sprays it in the dishwasher too and the orange rust stains vanish within 30 to 60 seconds.
PaulBob is offline   Reply With Quote
The Following User Says Thank You to PaulBob For This Useful Post:
Windows on Wash (08-18-2014)
Old 08-18-2014, 06:19 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,204
Put your engineering brain to work for me on some soap scum remover would you...!
Vinegar just ain't cutting it, pardon the pun, anymore.
By the way, how would that homemade H3P04 affect grout. I usually neutralize my stuff right after I am done.
Tags
rust stain , vinyl siding stain
DIY - Vinyl Siding over Cedar Shakes rebelranger Remodeling 9 08-02-2012 09:47 AM
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 10:23 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
