Rust Stain On Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-09-2006, 02:58 AM   #1
Rust stain on roof
Does anybody know what I can use to remove a rust stain on an asphalt single roof? I have tried lime-away, this did not work. The rust stain was from a flashing around a chimeney. The stain starts from the top of the roof ridge at the flashing and goes all the way down to the gutter. I repaired the flashing so it won't continue rusting, but really wish I could remove the stain too.
Thanks.
krtw is offline   Reply With Quote
Old 07-09-2006, 10:10 AM   #2
Commercial Roofing
AaronB's Avatar
Change the shingles?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 07-15-2006, 07:06 AM   #3
Rewards Points: 14
Originally Posted by krtw
Does anybody know what I can use to remove a rust stain on an asphalt single roof? I have tried lime-away, this did not work. ...
Oxalic acid. Look for "wood bleach" in the paint department, or "Zud" in the cleaning department. Wet down the shingles in the whole area first then spray the concentrated solution directly onto the rusty areas only. Let soak for about 5 minutes then rinse off with a hose. Oxalic acid is not a particularly strong acid, but it is a strong irritant - getting it on your skin, eyes or in your lungs (breathing the vapors) is very unpleasant.
C-L-R, btw, contains Sulfamic acid which is much better at removing calcium-based depostits but inferior at removing rust. Don't know what is in Lime-Away off the top of my head, but it likely contains sulfamic acid based on its name.
allpraisebob is offline   Reply With Quote
The Following User Says Thank You to allpraisebob For This Useful Post:
curtd (01-17-2015)
Old 07-27-2006, 04:10 PM   #4
THank you......thank you.......thank you.......thank you.......
OXALIC acid worked wonders. My stain is GONE. What an eye sore that was, I really hated it. THe house is really nice looking, but the big stain on the roof would always catch my attention from day 1 (I bought this house in January).
Thanks again. Praise be to BOB.
The Following User Says Thank You to krtw For This Useful Post:
curtd (01-27-2015)
Old 08-11-2006, 01:00 PM   #5
Rewards Points: 14
Glad I could help! Keep the oxalic acid around in case of rust stains on concrete, wood fences, stucco, etc. It bleaches the heck out of wood, though, so it's not really a good spot treatment for that - great a making a grey, weatherbeaten fence look brand new again, though.
Old 08-27-2006, 04:32 PM   #6
roof stain
I have the same rust colored stain on my asphalt shingles I followed your comments and tried Zud powder and it worked great in taking off the stain in a small area. I have 2 questions though:
1) Did you make a solution by mixing powder and water and apply with a garden sprayer and is it safe on shingles?
2) As far as where the stain is coming from, I can't be sure. I have all stainless chimney and aluminum flashing. I think rust is coming from my oil furnace gases. The furnace is 18 years old but it was cleaned and we found no rust. What else could it be?
mgaa is offline   Reply With Quote
Old 03-24-2008, 10:15 PM   #7
Why don't you try muriatic acid coz' it works by eating away the surface material, thus removing the rust along with some brick or concrete. It does remove rust stains better than oxalic acid, but is very corrosive and toxic to humans, animals and plants.
Carol Billups is offline   Reply With Quote
Old 09-24-2008, 12:50 PM   #8
Sweat Equity Guy
Rewards Points: 20
This thread is 2 years old, but I stumbled on it looking for a fix for this topic using an internet search engine!
I am going to go out and buy some oxalic acid and give this a try... I will post before and after pictures soon!
Thanks you!
mbkerk is offline   Reply With Quote
Old 06-04-2009, 08:33 PM   #9
Roof Leaks
Has anyone noticed a roof leak or stones falling off the shingles after using the acid? I don't want to damage my roof. Thank you.
Marine0302 is offline   Reply With Quote
Old 06-04-2009, 09:48 PM   #10
Sweat Equity Guy
Rewards Points: 20
Thanks for bumping this thread up "Marine0302"! I had forgotten where I had seen the information I learned here until I got the topic reply notification! (I belong to too many web forums!)
I still have not fixed my problem, however I will be getting to it soon as I have to get back on the roof to replace the chimney cap that I removed to repair a week or so ago. When I do that I am going to do something with the flashing to keep the rust in check, and then clean the rust off the roof!
I have been trying to avoid this as the roof is a 12/12 pitch and I don't like being up there...
I will get before and after shots when I do it, and will post them here as promised soon.
Old 06-10-2009, 04:45 PM   #11
How did you remove the rust stains from the flashing around the chimney? I am replacing the shingles but would prefer to clean the flashing in order to prevent staining the new shingles.
holmes55 is offline   Reply With Quote
Old 07-05-2009, 10:22 PM   #12
Sweat Equity Guy
Rewards Points: 20
I am having trouble finding any of these brands in my area. I have looked at Menards and Lowes. Any ideas, or other brands to look for?
Old 10-20-2012, 01:57 PM   #13
Oxalic acid works for even old rust
I know the post "how to remove rust from asphalt shingles" is old, but want to thank those who recommended Oxalic acid. We had our house totally remodeled in 2008 and have been fighting with the contractor over issues ever since. The rust stain on our roof appeared only a couple of months after the job was "completed" (they never tarred over the screws on an exhaust vent) and I finally got fed up.
Oxalic acid cleaned the rust completely even after 4 years. It may actually have helped that the surrounding shingles ("weathered wood" color) have had time to lighten a little from the sun, otherwise the rusted area would have surely turned from a rust streak into a bleached streak. The area had been constantly rusting the entire period because I never replaced or covered over the nails because I expected the roofer would have to come back and replace them. I'm getting to the point where I'd rather just fix the remaining issues (mainly cosmetic) myself because I know this way they will get done right. But I couldn't do it without this forum. Thanks again!
RSmall is offline   Reply With Quote
Old 09-18-2013, 06:02 PM   #14
Post
roof rust on asphalt shingles
The use of Wood Bleach by Savogran (oxalic Acid) worked wonders on the roof and the stained chimney flashing. Good tip.
Lems is offline   Reply With Quote
Old 10-24-2015, 06:11 PM   #15
Rewards Points: 4
I know this is an old thread....hopefully, some of you are still on here.
I tried home depot, lowes, menards, sherwin williams and a local store today to no avail! So, I guess I need to order on like amazon or something. I have seen some not so favorable reviews. Does anyone recommend any brand or place to purchase?
Treshomes is offline   Reply With Quote
Tags
rust , shingle
rust on nails in attic on one side of roof only this old house Roofing/Siding 3 01-27-2007 10:56 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Stain on Asphalt Shingle Roof stevedunn Roofing/Siding 2 10-22-2006 12:54 PM
rust stains on roof mgaa HVAC 2 09-28-2006 12:32 AM
