Rust On Nails In Attic On One Side Of Roof Only - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-27-2007, 01:26 PM   #1
Question
rust on nails in attic on one side of roof only
hello everyone , i have one problem , way would there be rust on the nail bottoms in attic of the roof on one side of the house. what could be cousing this. do i need more insulation up there or somthing. its only r19 at the moment. till i get more money. and there are no leaks.
thanks
dan
this old house is offline   Reply With Quote
Old 01-27-2007, 09:39 PM   #2
remodeling pro
What climate do you live in. It sounds like there is a problem with warm air getting to the exposed , cold nail tips and causing condensation on them (assuming a cold climate) Is there any type of hot air ducts in the attic that could be leaking? What about water heater or furnace vent stacks? How close is the roof deck to the ceiling in the problem area. There could possibly be enough hot air escaping through wire and pipe penetrations in the upper wall plate to reach the nail tips if the roof pitch is very shallow. Is this problem on the "windward" side of the roof? Another remote possibility is that the shingles are nailed too low (below the seal strip) , thus wind driven rain may be seeping down the shanks.
troubleseeker is offline   Reply With Quote
Old 01-27-2007, 09:42 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Initial concern: Lack of proper attic ventilation. Moist, damp air gets trapped =can cause rust on interior fastener surfaces...
Do you have any kind of proper ventilation? ... in your roof, Attic, or Soffit? Regardless of insulation: If your rafter cavities are insulated, do you have rafter venting installed as well?
- Build Well -
Old 01-27-2007, 09:56 PM   #4
Another Thought: Only on one side?.... hmmmm....
Question: Is the side you are referring to - the side that the sun rises onto in the a.m. ? The side that receives the sun in the early part of the day???
- Build Well -
Rust stain on roof krtw Roofing/Siding 15 10-24-2015 05:17 PM
Protruding nails through exterior patio roof miami789 Roofing/Siding 7 06-25-2007 02:42 PM
Attaching Roof to side of home joe3534 Roofing/Siding 1 04-29-2007 09:54 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Framing Attic Walls but Roof Has SAG! luckestryke Building & Construction 1 04-27-2006 08:40 PM
