Rust Coming From Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-24-2013, 08:13 PM   #1
Rewards Points: 12
Rust coming from chimney
Had rust stain on shingles coming down from chimney to gutter for years. Finally had replaced with faux brick veneer and new flashing. But rust has returned. Anyone know what's causing this? I've heard that there are some acids that work well on rust but I need to fix this. Please help, thanks.
scottb88 is offline   Reply With Quote
Old 06-24-2013, 09:15 PM   #2
Roofmaster
Rewards Points: 2,172
Not to be a master of the obvious, but you've got Iron rusting somewhere in the Mix. Pictures?
Old 06-29-2013, 09:19 AM   #3
roofingquotes's Avatar
If you replaced all the needs to be replaced then I don't get the picture.
roofingquotes is offline   Reply With Quote
Old 06-29-2013, 11:28 AM   #4
Bill Kearney
Rewards Points: 1,174
There's something else in there that's getting wet, corroding, and leaving stains as the water runs down. The question is what or where is that material?
Some pictures of the stains and upward from it would help.
wkearney99 is offline   Reply With Quote
Thought on rust particulate coming up a new drilled well? GuyFromTheNorth Plumbing 9 11-13-2012 02:35 PM
Chimney Drafting Seems Un-Solveable dwk02020 HVAC 63 10-17-2012 08:25 PM
Chimney Rattles/Sways in Windy Weather cprice12 Concrete, Stone & Masonry 10 09-28-2012 11:36 PM
Chimney moisture issue. DaveMoss General DIY Discussions 2 10-24-2011 03:57 PM
Roof leak around my chimney - update GlennAble Roofing/Siding 3 11-05-2009 07:24 PM
