Rust - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2013, 01:18 AM   #1
rust
remove rust stain on roof
phill anderson is offline   Reply With Quote
Old 05-01-2013, 01:28 AM   #2
Doing This Way Too Long
Rewards Points: 532
OldNBroken is offline   Reply With Quote
Old 05-01-2013, 05:44 AM   #3
roofingquotes's Avatar
What kind of roofing shingles you have?
roofingquotes is offline   Reply With Quote
Old 05-01-2013, 03:22 PM   #4
Metal Roofing
Rewards Points: 600
Rusty ones
AndyWRS is offline   Reply With Quote
Old 05-01-2013, 03:29 PM   #5
Rewards Points: 12
Daubert VCI makes a rust inhibitor called Evaporust that works extremely well on rusty parts by inhibiting corrosion-causing chemicals.
http://www.evaporust.com/
I've used it on rusty bolts, parts and tools at home and it works very well. It's non-toxic and safe to use on many materials.
Check out the link - pretty sure you can get some at any auto parts store.
rkingndayton is offline   Reply With Quote
Steel studs rust basement help bergerdude Building & Construction 17 10-02-2013 01:24 AM
Rust converter (phosphoric acid) not working Studly Automotive Repairs 3 05-02-2013 06:57 PM
I-Beam, Rust & Concrete kinghong1970 Concrete, Stone & Masonry 13 03-29-2013 11:59 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
