Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-06-2007, 06:01 AM   #1
rubber or torch
I need to replace a rubber roof and have had 4 roofers look at it. One gave me a offer to go with a rubber roof or a torch roof. What is the pros / cons, benefits on both, what is better and why and which will last longer and is stronger, etc.
I can not find info on torch.
Torch is 280 cheaper.
jcd34 is offline   Reply With Quote
Old 08-06-2007, 02:46 PM   #2
rubber or torch
Rubber is a lot better but only if its done by a crew who is trained for it. Torch down is considerd lower end but can also be a good roof .
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Old 08-06-2007, 07:46 PM   #3
Super Moderator
rubber or torch
Depending on what the terain around the roof is like and the amount of debris which may wind up on the roof surface.
The properly installed EPDM roof with the flashings done per spec and fully adhered is a very durable roof, except for roof top debris.
The APP Modified Bitumen Torch down roof is more meaty and durable, but presents additional fire hazards during the installation process.
Neither is recommended for a DIY project due to the importance of what a roof covering does for protecting your valuable assets indoors.
Ed
Ed the Roofer is offline   Reply With Quote
patching a rubber roof rade0041 Roofing 2 05-11-2007 11:17 PM
Stripping rubber padding off a parquet floor nubee Flooring 1 04-22-2007 02:08 PM
Cost of Torch Down vs. Shingle Misha Roofing 2 10-02-2006 04:21 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing 4 12-17-2005 06:39 PM
Torch Roof Replacement Question Chad262 Roofing 6 09-21-2005 08:29 AM
