Rubber Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-25-2011, 05:43 PM   #1
rubber roofing
I have a ware house that is store front. The roof blew off and I want to replce with white rubber any suggestions?
tsweet1000 is offline   Reply With Quote
Old 06-26-2011, 07:32 PM   #2
Doing This Way Too Long
Rewards Points: 532
Sounds like in your situation the best suggestion is call a reputable
commercial roofing contractor. Single-ply roofing (TPO, PVC, EPDM), or what you call "white" roofing, is generally not a DIY project. The equipment and experience to do a proper job are beyond a DIY
OldNBroken is offline   Reply With Quote
Old 07-06-2011, 11:34 AM   #3
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Rubber can mean a number of things. I hear people calling modified bitumen "rubber" but it is not. Broken touched on numerous flat roofing options. Without knowing much about the exact circumstances, my preferred membrane of choice is TPO or PVC.
True rubber is EPDM. EPDM is most commonly black but a white EPDM is also available. White EPDM costs more than black. Again I prefer tpo or pvc which are also white, but are not rubber. Why do you want a "rubber" roof? Which kind of "rubber" do you want?
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Is rubber roofing servicable as a deck floor too? PaulinWatertown Flooring 8 05-12-2011 09:25 PM
EPDM Rubber Membrane Roofing Q's flatlander745 Roofing/Siding 1 04-01-2011 06:44 PM
ice and sleet shield under rubber roofing sthaney Roofing/Siding 3 11-21-2010 06:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
rolled vs. rubber roofing felix Roofing/Siding 4 03-01-2006 10:16 AM
