Rubber Roof How To - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-11-2013, 06:40 PM   #1
Rewards Points: 12
Rubber Roof How To
I am going to install rubber roofing on a very low slope roof that had rolled asphalt on it. I will remove this and put down "corn" board??? that's what my local lumber yard called it. I need to tie into fiberglass shingles on two sides that are a steeper pitch. I am looking for a how to video or guide in anyone has any suggestions??? I am going to put ice and water shield on the lower part of the steeper roof....do i put the rubber roof under that or on top of it???
norm58 is offline   Reply With Quote
Old 09-11-2013, 08:46 PM   #2
I would remove at least the bottom 3 rows of shingles. Run the membrane up and shingle the 3 rows back in.
bigfishcatcher3 is offline   Reply With Quote
Old 09-12-2013, 11:25 AM   #3
Low Slope Roofing
Rewards Points: 114
I'm not sure what corn board is but I'm guessing Fiberboard. For tie-in you will need to remove how ever many rows of shingle to get the membrane up the sloped roof around 12", glue it directly to the plywood of the slope roof, don't forget to RTS, the transition change.
Then re shingle and felt as needed to bring the leading edge of the shingles down to about 8" above the slow slope roof deck. No ice and water shield needed just felt if needed.
1985gt is offline   Reply With Quote
Old 09-12-2013, 08:07 PM   #4
Rewards Points: 12
What is RTS?
Old 09-13-2013, 11:58 AM   #5
Low Slope Roofing
Rewards Points: 114
RTS is reinforced termination strip. It goes down to the deck/wall when ever there is an angle change in EPDM. It keeps it from bridging later on in life.
PDF of the details...
http://www.versico.com/documents/reslib/VGC-13.5.pdf
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
rubber roof Fanatic Roofing/Siding 2 11-10-2011 03:16 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
